Honor Magic 5 Pro
yhw22
Anyone can confirm giga! got VoLTE? As not sure MY or SG set got different or not.
miraclesz
Currently holding magic5pro. Tempted to get oppo find N3 flip . Is this considered a downgrade?
T3rmite
VoLTE enabled for M1.
Not sure is it because of the update or because M1 enabled it.
The VoLTE appeared after 7.1.0.197 update
i_dun_understand
Anyone experienced NFC Google pay issue after latest update 7.1.0.197 ?
Phone updated to this update last night. This morning board the bus was working fine. When alighting the bus, hit error saying software does not meet Google pay standard.
Then try again at MRT gantry also same error. Restart phone also did not solve the issue
ChickenLitter
can i check if the data/appointment in samsung calendar can be transferred/port over to honor magic5 pro calendar?
i_dun_understand
I have try factory reset my phone but same problem.
Just try to use Mac Donald App with similar error. Security check failed. Please check and run trusted Google OS.
Anyone encounter similar issue after latest update to 7.1.0.197 ?
DeepseaG1523
i have no issues.. maybe u wanna try to clear google play services cache and see if it works
i_dun_understand
Having same issue, any luck with reinstating firmware version?
You also have the same issue whereby unable to use Google Pay NFC / Mac Donald app ?
I went down service centre over the weekend. They have try to install earlier version/batch but still unable to resolve.
Did another reinstall without batch 3 update (left it pending) also unable to work.
chronorec
Yea also same thing due to the latest update, but my corporate apps (outlook, teams) are still working, so don't know if it's an Honor problem or Google pay problem.
i_dun_understand
I believe is honor security patch issue with google. When I factory reset my phone earlier before going to service centre, Mac Donald app also unable to setup successfully. It mention Google OS not trusted.
The last time I see same error was using Huawei phone and sideload Mac Donald app as it require a valid Google play store.
chronorec
My Mcdonald app is able to be used if I don't pay by Google pay and instead just keying in the cc details directly, so it's still workable for me
