Honor Magic 5 Pro
phiber
My M5P can utilise both QC and PD for fast charging.
I saw some reviews it does only 15w or 25w on PD / QC.. is that true? not even 45w?
Anyone can test charging with a charge display and PD charger?
xonix
check your charger support what type of charging speeds
this is copied from their spec sheet:
Wired Charging​
HONOR 66W SuperCharge
The phone supports up to 11V/6A SuperCharge, compatible with 10V/4A, 10V/2.25A, 10V/2A.
https://www.digitaltrends.com/mobile/how-does-fast-charging-work/
SuperCharge automatically adapts the incoming wall voltage and current based on the condition of the phone’s battery and the phone’s internal temperature. Older SuperCharge-compatible wall adapters and car chargers support three charging modes — 5V/2A, 4.5V/5A, and 5V/4.5A (up to 22.5W) — and use an in-charger chipset to regulate voltage, eliminating the need for heat-producing in-phone voltage transformation. The latest version offers 10V/4A for up to 40W.
Unlike proprietary charging standards like Pump Express and Dash Charge, Supercharge is compatible with USB-PD. That’s thanks to Huawei’s Smart Charge protocol, which intelligently switches between charging modes depending on which charging adapter is plugged in.
Tapping into Huawei’s SuperCharge technology requires buying a compatible wall adapter, but native compatibility with Qualcomm’s Quick Charge standard means any SuperCharge-compatible devices can take advantage of Quick Charge. Every SuperCharge-compatible smartphone comes with a compatible wall adapter.
xonix
Feel like Honor trying upsell the PRO model :unsure:
DeepseaG1523
amigoeva
I'm intending to get the Magic 5 instead of the Magic 5 Pro. Anyone knows of any shop that's selling local set?
DeepseaG1523
Magic 6 launching soon already.
Looking at magic5 pro MWC event was on 27th Feb 2023
MWC 2024 is schedule for 26 - 29 February 2024
The earliest u will see magic6 will be late march 2024 or maybe even Apr 2024
so still got few mths to go
magic5 pro still can buy if u need a phone now (y)
shager
Do all the local telcos have volte support enabled?
anthonygreenisreal
Yes can buy but please buy at good discounted price. Don't pay full RRP for it now.
