lao3hero
- Jul 26, 2008
yes can workAnyone tested if singpass working with china rom?
Singpass and all banking apps are in apps gallery for non gms set.Isit using gbox or gspace? Thanks bro
I contacted Honor support and was told that V2 support only 3g and 4g here. Think Honor did not enable 5g setting.Got 5G using my Singtel line.
Oh that's strange. i was at singtel on friday to collect my iphone and switched my singtel sim card to hv2 and i vividly rem i saw the 5G logo on the phone. Let me switch my singtel sim card later to the hv2 and do a screen shot.I contacted Honor support and was told that V2 support only 3g and 4g here. Think Honor did not enable 5g setting.
Not true...Im using Singtel 5G. the 5G logo shows up. Speed wise I dont know, haven't benchmarked.I contacted Honor support and was told that V2 support only 3g and 4g here. Think Honor did not enable 5g setting.
I am suspecting why M1 and Starhub cannot go into 5g mode. Singtel seems to be working. Any one can confirm M1 and Starhub?Not true...Im using Singtel 5G. the 5G logo shows up. Speed wise I dont know, haven't benchmarked.
Also, not sure if VOLTE / VOWIFI is working as the corresponding labels are not displayed. Unless anyone can give some short codes to key into the device to check
I am suspecting why M1 and Starhub cannot go into 5g mode. Singtel seems to be working. Any one can confirm M1 and SUsi
I'm using Starhub on my HMV2. so far only seen 5G once at Suntec near Uniqlo.I am suspecting why M1 and Starhub cannot go into 5g mode. Singtel seems to be working. Any one can confirm M1 and Starhub?
I suspect as much too. Once they launch a global rom version, I'll just buy it from Malaysia or whichever (shopee/lazada) that imports it at a reasonable price.Have a feeling they won't launch in sg, noticed that the few Chinese brand like vivo, oppo or honor don't launch their Flagship in sg, likely because demand here for the better phones not high. Just hope it will launch in msia and buy from there
Maybe not all areas got 5G network yet. You may refer to the website for reference: https://www.nperf.com/en/map/SG/-/-./signal/Ok to clear all the 5G stuff. Tested a few locations. Using 2 telco and it is only 5% of the time it will switch to 5G. Not sure why. Have a pixel fold at the same time and is basically full time 5G.
Conclusion is 5G working but very selectively.
I actually doing real time comparison with pixel fold side by side. Just that pixel fold is 5G but V2 still 4G. Not sure why. But I think Honor can do some configuration? No choice have to live with it.Maybe not all areas got 5G network yet. You may refer to the website for reference: https://www.nperf.com/en/map/SG/-/-./signal/
Yes. you are right.I think the 5g band availability is the reason.
so far their foldable phone since day 1 no people have complained.candy bar not so worried but foldable is quite scary, somemore this v2 is so thin.
I shall wait for local release next year.. don't wan risk.
i see xiaohongshu got alot of 翻车 post on magic v2 so i rather not riskso far their foldable phone since day 1 no people have complained.
I have receive SMS from Honor Club that I have been selected in the Firmware beta program and was informed that they are testing the Wechat in Google Playstore on the separate screen function but does not affect the normal Wechat operation, I have submitted my agreement to go ahead with the Firmware Beta program so I should be receiving my Firmware Update soon!I just receive my CMLink Sim Card today, activation is pretty fast and submit application for the 1CMN, approval was within few hours instead of the mentioned 5 days so I turn on the SMS and Call forwarding after login into my CMLink account.
I went to register the Honor ID in my Magic V2 also the Beta Club then fill up the form and submit so now waiting for the update of firmware.
