eyz
- Jul 10, 2002
i also drop one time , now a lot of scratchs on my v2, sibie sian.
are you using it naked?
only with back cover.are you using it naked?
HI all bros and sisters, Can i check what is the best and thin casing you all use for your V2? Looking online but not sure what to get as if its too bulky the casing then defeat the purpose of the HP being light and thin in the end.
Appreciate all suggestions.
Thank you![]()
CN sets owner take note,
the latest upgrade to 124 will render your gpay useless.
hold on to your update if possible.
CTS profile match failed.
btw, the new update has smart capsule, which I'm not sure how it is use between the inner and outer screWith smart capsule supposed to work like
Nice. Thanks. Just updated and magic capsule is working perfectly
Bought a pre-loved unit yesterday. As this is my first Honor phone, hope I can get some help to my questions below:
1) Default message app is Google?
2) Is it a must to set-up a Honor account? If no, means no software update?
3) How do you on/off the phone? When I pressed the side button, it activates Google assistant
Appreciate all help in advance.
Thank you.
Thank you very much!i assume yours is global set. yes the default messaging app is google, same goes to dialer if i am not wrong.
not necessary. you still get update without Honor account. but with huawei or honor account, you are able to do cloud backup.
if i remember correctly, you just have to continue holding the side button. there's a message at the bottom.
enjoy your new phone.
Just turn off the notification will doAnyone using Microsoft SwiftKey as keyboard. Time to time I will get notification by Android System to select keyboard - Microsoft SwiftKey keyboard. Anyone else encounter this?
Anyone knows if the local set warranty covers for screen breakage or damage, or replacement of display?
If you purchased local set during the pre order period den yes got screen protection, if not no.the last time someone asked the same qns, hasn't update us on this issue yet.
May I know any of you intsall Intune on V2? Does it support and work well?
