Honor Magic V2
tspurs
cos i saw find N3 prices are now cheaper than V2 especially used ones.
Haha I also saw the same, and had the same question. I thought the two were pretty even - one has better cameras and multitasking, while the other has better form factor and battery life.
otts
i think maybe bcos n3 is out earlier and more telcos carrying it. i'm on the fence w this 2 model cos wanna try my first foldable
Globe
anyone can install douyin after upgrading to os 8.0 ?
keeps giving me error even after giving access to side load the apk
Globe
it just pop up say app not install after i run the installer.
i had to send my phone in for inner screen repair and scrab my hp clean, so have to do a reinstall
froztheart
If Global ROM, check your Google Security Scan, it blocks app installs even with "Side loading" enabled.
Globe
how do you access this ?
i search both in phone and in googled this google security scan but nothin came up
TIA
froztheart
TIA
Google App Store > Play Protect > Top right gear icon > turn off all settings.
Then try again, it should work, since I faced this when trying to Install 抖音.
DeepseaG1523
  1. Open the Google Play Store app .
  2. At the top right, tap the profile icon.
  3. Tap Play Protect Settings .
  4. Turn Scan apps with Play Protect on or off.
After that should be ok liao..
DeepseaG1523
Just now lunch time, i go Challenger walk walk see see..
I saw Magic V2 drop price to $1799 😲😲😲
DeepseaG1523
Let's just hope it will be just be a 1 month or 2 months wait after china launch for local launch.
Seeing the leaks, it it going to be even thinner than V2. 😲
wildpig8
Hi to all users of V2
I am thinking of jumping ship from Mix Fold 3 to V3 (after it is launch).
May i know is there any major compatibility/software issue especially for important Apps like singpass,banking apps etc?
May i know is there any big difference in China ROM and Global ROM?
Any CN set user here have issues using it in SG?
Or is it more advisable to get local set?
Thanks in advance!
Seifer28
Thanks in advance!
V2 CN set user here
Been using it for like 4 months or so
No issues that im aware of
eyz
Thanks in advance!
major difference is local set has vowifi and android auto. some say local set has more compatible network band for use it Singapore, but i get 5g all the time on my cn set.
cn set has access to chinese theme store and more function with the magic pen.
feel free to add.
