Honor Magic V3
aw1007
I ask Honor sg about the removing of outer screen sp ...they say ok to remove and replace our own favourite sp. Just not the inner screen.
This should be the case....doesn't make sense changing outer screen protector will void warranty...
After using the default case for a while, finally removed it and using it naked + front TG. Just have to be extra careful from now on.
Welcome to the club...
cth
If you are using the phone for work, dun buy green.. Wait u work until face green green..
Besides aesthetic reasons, can also consider weight when choosing black or green/red. Black is slightly lighter compared to green/red.
eddy0505
Used both CN and Global XFold3 pro previously, still prefer the sleekness and UI of V3 more.
Of coz, camera and battery capacity aspect XFold 3 Pro still wins..
Was the gap in battery/camera big compared to magic v3? Maybe I hand itchy will hoot a 256gb fold 3 pro china rom just for testing lol.
aw1007
Zooming still XF3 pro wins .....would says marginally.
Front screen, V3 better ...wider and easier to use. Better feels in hand.
eddy0505
Doesn't sound interesting to try liao lol. Was your global vs china rom experience very different?
Computeron
What made you decide to dispose of the 16pm?
I came from 15pm. 16pm only gave me slightly bigger screen n battery only.
I always watch videos on my way to work n home. So a bigger screen is a big advantage. V3 battery's life is on par with ip15pm
aw1007
Actually the global set is not really the 'global rom standard'..quite shitty implementation, like apps compatibility much worse than CN rom. At time I off-loaded the set...some apps just simply "enlarging nia".
Understood...only released in 2 countries, dun think they will channel much effort to perfect it.
And the "global rom" sets are still selling at more than 2.4k now..
eddy0505
Can share if it feels a lot lighter. And also, is it more slippery now?
A lot lighter, initially wanted to use without but was concerned about the camera lens so put back the case. Now I gian the feeling of using it naked. Mine is red brown set so still ok not slippery.
eddy0505
Seems like no point getting global rom. Thanks for the review. Guess I'll just get one to play play during sale haha
eddy0505
I'm using the default case. Ur tg from where de?
I go carousell find ppl custum made hrdrogel liao tml.. I ocd
https://a.aliexpress.com/_olYHfoJ
mine this kind, had sale so bought about 3 bucks. You shud be able to find similar kind on shopee or taobao etc maybe cheaper. Else those not fully covered de might work too. Yours totally can't fit or adhesive not strong liao?
