Honor Magic V3
Amuroraysg
I finally ling wu the essence of knuckle circle to search.. u need to knock and hold your knuckle there straight away draw instead of knock lift your hand then put your knuckle down and draw.. work flawlessly
NeonX
if anyone offloading the pen let me know pls, am interested to get it
eddy0505
Hey guys my phone seems to have some problem with detecting GPS. I'm wondering if it is just my set or are there others with this problem.
Basically every now and then, my Waze (and Google Maps) will say No GPS detected and fail to update my car's position for like 2-3 minutes or so.
Opening the other app (I'm usually on Waze) Google Maps will also have No GPS detected. Closing and opening the app doesn't help
I've also tried out a fellow forum-er's advice to
"Go to app launch > waze > toggle auto off and make sure all 3 manual toggles are enabled. Thank me later or can donate to my link lol. These are minor bugs bcoz china phones like to migrate /clone their china rom then repackage as global rom. Just simple tweaks will make things work again."
But the problem still persists.
Anybody has the same problem or is it just my set?
This one seems like gps issue not the disconnecting issue tho, maybe check if ur navigation apps has the necessary location permission?
rashcrash
For those who play mlbb and find the controller at extreme corner hard to control, u can still play in other screen orientation ..switch to "force device orientation with original protrait ratio" .
The game can be played with the phone upright and the controller will have more space for thumb to move around.
Hmm may I know where to find this option as I could not find this anywhere in the app or settings
Computeron
Just msg DV Tech, he said current they are sorting the pens for the first wave of buyers. I'm second wave.. Lol
White Shader13
I had this issue but after an android auto update it stopped. Perhaps try to see if there is an update for AA.
However, AA will sometimes still not be able to connect to my radio app. I have to manually launch the app in the phone then it will play to the car via AA.
NeonX
Do you guys switch off the smart battery capacity option?
Wondering if I should turn if off for maximum battery daily haha
avsquare
I wish they just do it like one UI, just click and hold the bottom to activate the search feature
Innocuous*
After 5 working days of usage, I observed that V3 battery drains slightly faster than my Huawei Mate X3. In terms of battery charging, V3 is about as fast as X3. V3 has cards which is similar to widgets in X3 but selections are rather limited. Even though V3 is slightly slimmer and lighter than X3, I can observe significant better holding experience in V3 when used over long period of time reading ebooks and watching videos. V3 is a worthwhile purchase. If Honor can produce thinner and lighter Magic series, I am prepared to purchase another Honor phone to pair with V3.
KeoNxaGa
I tried number 2 and still didn't work. The screen will just blank even in the charging mode.
I would like to try option 1
How to navigate to the developer option ? Stay awake when charging?
  1. Go to "Settings"
  2. Tap "About device" or "About phone"
  3. Tap “Software information”
  4. Tap “Build number” seven times. ...
  5. Enter your pattern, PIN or password to enable the Developer options menu.
  6. The "Developer options" menu will now appear in your Settings menu.
