Honor Magic V3
NeonX
Look like just paste skin for better grip..really cannot drop..once drop..warranty for screen will be voided.
Huh is it? Got such thing one ah?
I still waiting for carbon fiber case from China, dunno if it will be better than the default case
aw1007
Do you have the link to this case? Is it any good? Seems like no protection on the front outer screen?
This is the back skin...not case.
Coz OP asking, using caseless and decal..
Got it from TB
【淘宝】限时满35减4 http://e.tb.cn/h.grmghE7AMHOXFgs?tk=94F23i9IWaJ CZ3460 「魔力鸟适用于荣耀Magic V3全身膜后膜magicv3背膜荣耀V3全贴膜贴纸包边框膜保护膜贴膜边膜改色膜镜头贴轴」
点击链接直接打开 或者 淘宝搜索直接打开
luxerio
huh, YouTube shows a lot of videos liao. It can survive drops with minimal damage. Hence, I am not so worried about that, just concern on scratches. So I guess a decal / skin should work for better grip and reduce scratches.
Ray1976
This one totally no protection. Front u can just paste a tg protector
I am still using the stock case from Honor. IMO this is better than no protection of the frame and hinges when drop or knock against a hard structure. So far, we are not sure what does the 365 days outer and inner screen protection mean...due to user negligence w/o a case and drop to a hard concrete floor and caused the outer screen to crack - mind you, Honor claimed that their so-called King Kong Gorilla nano shield is very very scratch resistance and hard...some Youtubers already putting the device in a washing machine and some did many rounds of drop test etc...and the screen failed to crack under any kind of presssure.
Computeron
Same using default front n back case. Mayb after 8 mths I go naked... Lol
elementz
I ordered a carbon fiber case from Taobao 2 days ago. Then I realised it chose sea freight as default. Now gonna wait 1 month for the case to arrive. Sianz.
Justbear
If cheap then get another one. The sea one came then sell.
rebornsoul
Anyone know how to enable notifications for all apps? Mine seems to be set to disabled by default for most apps.
And any idea how to open email attachments in full screen instead of the floating window?
glorygoh
No luck, u'll have to go to all individual apps to see one by one if they are On or not. As for email attachments full screen, mine sometime full screen sometimes floating, I'm sure there there is some trigger factor. Eg if ur outlook is in floating win, then attachment will be in floating win
KeoNxaGa
China set? No issues on notifications for my global de leh
ralfale
Is there a way to do horizontal split screen so I can netflix on top half and chrome at bottom half?
