Honor Magic V3
Niceusername
Is there a way to do horizontal split screen so I can netflix on top half and chrome at bottom half?
Usually I only do vertical split, but from vertical split, there is a '3 dot' between the split screens. Press that and U will get the options to chose horizontal split.
doki81
Unfortunately, you can't. This is due to Netflix app unable to do horizontal split.
Actually can...I have netflix and prime on split vertical..just that I can't get both movie to play together. Can only play 1 and pause 1 quite silly 😜
Ray1976
I knew it can do Vertical split (Left/Right). Everybody knew that. 🤦‍♂️We are not talking about that. The OP is asking whether it can use chrome and netflix doing horizontal split (Top/Bottom).
Ray1976
A huge difference between using the Pro mode and the typical Point-and-Shoot mode when taking an image in an indoor setting with different lighting.
Pro mode
Normal PAS
The pro mode lighting at the Burger King outlet is closer to what I saw. The normal PAS will try to auto-correct the AWB.
Ray1976
The usual moon shots taken with the Magic V3. Nothing to shout about these days.
Shot at 50x zoom
Shot at 100x zoom
aw1007
Pro mode
Normal PAS
Wow.. didn't know that is huge diff...
Ray1976
And yes...finally gmy hands on the Magic Pen yesterday. I'm pretty impressed with the feel. Very well built. Way better than Samsung "plasticky" S-Pen.
nokia09
anyone knows why the wifi seems slow even when it shows wifi 7? my flip6 wifi is much faster when on wifi6e
doki81
Oops typo .I wanted to say horizontal but my hand type vertical.. 🤣
Ray1976
Yes, Honor Magic V3 do support WiFi7 which is the 802.11be protocol. As to why it is slower, you may want to play around with your router WiFi channels to see if it improves. Also you can use 5Ghz instead of 6Ghz, maybe that would help? As the bandwidth gets bigger, the distance between the devices and the router/AP gets shorter. Sorry, I don't have a WiFi7 router or AP, so can't help much. WiFi6 (ax) is already plenty of bandwidth to go around...I can literally stream 2 concurrent 4K movies streaming from my laptop and tablet with no lag.
NeonX
Yea I'm quite impressed with the magic pen too. Much better than the Samsung s pen
Any way to voice command or hand gesture when taking selfie?
Can do palm and smile in camera settings I think. Smile confirm can
Ray1976
Yes, for gesture. Open up the Camera app, go to <Settings>, second row, you will see, <Smart Capture>. The usual suspects like Gesture control showing your palm to activate the timer etc are all there.
Ray1976
Yes...very impressed with the magic pen integrating nicely with the phone. The pen even comes with a laser pointer. LoL.
ngsoonle
Anyone using Parents Gateway here? Just realised app unable to load on my V3...stuck at the initial screen..
