Honor Magic V3
rchow2008
I like the standard case . In fact love the design. I ordered a couple of other colours!
I’ve almost finished setting up (I like to make sure everything works before I switch my SIM over), just need to test I can login to all the apps and games now 😛
Ray1976
My IMAK tempered glass screen protector just arrived. Trust me, for all Magic V3 users, you will want to get this immediately!
Pasted it and it fits snuggly to the outer screen and guess what, I am able to re-fit my front case bumper on top of it w/o any issue. More importantly, the Magic Pen can also be used on the screen protector even though most shops will tell you NOT to use tempered glass protector. It doesn't affect affect the screen sensitivity when using the pen.
The feel of tempered screen protector is so smooth and more importantly, no more lint and dust debris sticking to the screen protector any more.
For those interested to get the IMAK TG screen protector, you can use this link below. It only cost $8+. The shipping takes about 4 - 5 days to arrive if you place your order on a weekday. So if you place it now or on Mon, it should arrive by Fri evening.
https://shopee.sg/Original-Imak-Hon...Screen-Protector-Film-i.202783274.28356057798
I have personally tried and confirmed it is case-friendly (if you are going to use back the front bumper case) and the Magic Pen worked too!
Ray1976
How come I tried and it prompts me that Netflix does not support split screens??
Is there some settings that needs to do done?
You need to go to Settings, look for Foldable phones option and then under "Force Multi-Window" option, scroll down to Disney Plus, Netflix, Prime Video or any other apps that you want to "force" using both vertical and horizontal split.
See pics...
After enabling those settings, you should see "Horizontal Split" as an option when you hit the centre divider with the 3-dots.
cyan4sg
See pics...
Thanks
rebornsoul
Anyone knows how to make the email app open pdf attachments in full screen? Not it's opening up the pdf in a small window....same thing happens when folded and unfolded
aw1007
Mine no issue ...365 as default apps to open pdf
winningeleven
I have personally tried and confirmed is it is case-friendly (if you are going to use back the front bumper case) and the Magic Pen worked too!
Do u removed the existing original screen protector or u just pasted the tempered glass SP on top of it ?
osirisx
Anyone knows how many years of android OS and security updates can we expect?
aw1007
Eh ...care to share what is the reason why need to pasting new one over (on top) the original one?
