Honor Magic V3
zobrak
I realised that Maybank app does not allowed me to proceed when the phone is under developer mode where the rest of my interbank banking still work
I want "always on display" when charging the phone and only the developer method work.
install in parallel space or private space
rchow2008
Maybe try installing in the Parallel Space and see if it works?
My ocbc app worked on first install, then 2nd time it hang, i closed and restart the app and it's working normally now.
Great idea to install in Parallel Space. Went to try, but then now the OCBC app works in the main space now. Seems like the advice to just keep trying works. 😃But now Citi stopped working…what is with these bank apps and super strict security (security is good, but I think this is taking it a bit far as loads of people like to side load legitimate apps). Will keep trying and update you all.
doki81
if you have china app for watch movie...or any other side load app. they will detect...please don't use those app as it's a risk of all your bank account empty by scammer .. :vijayadmin:
yhw22
I feel you too. I also need developer mode for other stuff. So I just use web to login.
White Shader13
Anyone using Garmin watches with the V3? I'm having this issue with the phone keeps losing memory of the device the moment it is far away from the phone and constantly having to repair them.
Getting annoying.
Ray1976
Yes for some odd reason I never thought of pressing the Notification Sound that is within each Notification settings. And the setting is just there. No vibration! So managed to switch it on. Not sure why it is switched off by default. Bugging me all day. But yes, all good now.
Finally!!! Something that works.
Happy for you...
doki81
Computeron
winningeleven
Getting annoying.
I connected using my Garmin 965. So far id ok. Just that it drain battery and I went to app launch to adjust the setting to prevent the app run in background
elementz
Getting annoying.
I used to have this problem with my previous Vivo phone. It will go away for a few weeks after I rebooted both the watch and phone.
So far haven't encountered this issue with V3.
zeight17
For those who prefers "One UI" icon themes. Works flawlessly. The red looks good tbh.
