Honor Magic V3
Computeron
this imak de...
curved edge..that's why can use case on it..
https://s.shopee.sg/6ASUbdBp1Z
Eek... Looks like the one I bought from tb. Black boarder, stick the sides only. Screen didn't stick one right?
This sp flex my front case.. Not gd one.
Computeron
is it, nb i order liao leh haha
This sp got thickness.. U put on front case, will push ur case up abit. Also will eat ur screen abit due to its black boarder.
If wan to use tg sp, best to buy smaller size one. If not front case sure got problem.
geekboy99
Maybe try installing in the Parallel Space and see if it works?
My ocbc app worked on first install, then 2nd time it hang, i closed and restart the app and it's working normally now.
kaiser_11
can you check if you have some other apps blocking notification?
check notification access settings, see which apps have been enabled
What sort of settings should I do there? There are only Android Auto, Google Play services, Honor Home, Android System Intelligences and Link to Windows. I just enabled them all.
Also did a factory reset on the phone, but still the same! No vibration for notifications.
tohchr
By default, there's no vibration for notification on mine.
U need to go to setting, notification and status bar, scroll to that particular app, all notification, notification tone, vibration, select the type of vibration u want.
Ray1976
Haha...I will know what @kaiser_11 is going to say, "I have also did that too and nope, still no vibration for notifications". Seems like all avenues exhausted and whatever advice members can give all given. All at wits end. Last resort is to seek Honor's tech assistance.
It is hard to fathom why majority having no issue except for his phone. Even after a factory reset and re-downloading the apps from scratch (assuming not restoring from backup) and still not working as intended. It cannot be replicated and seems to me that he might have a corrupted ROM of sort.
kaiser_11
Hello! Nope. I actually managed to solve the problem! Thanks to @tohchr!
Yes for some odd reason I never thought of pressing the Notification Sound that is within each Notification settings. And the setting is just there. No vibration! So managed to switch it on. Not sure why it is switched off by default. Bugging me all day. But yes, all good now.
Sorry, I'm still playing around with the phone and settings. Coming over from Samsung, some settings are not the same. Thanks all for your patience and all the advice! And taking time to answer all my posts and questions.
zobrak
@tohchr
samsung also hv this notification sound
winningeleven
I realised that Maybank app does not allowed me to proceed when the phone is under developer mode where the rest of my interbank banking still work
I want "always on display" when charging the phone and only the developer method work.
gonnie
In what way is it not working?
Clear that app cache and restart your phone. Make sure permissions are all granted.
the app kept restarting after i enter my biometric or password to login :(
tried above but cant work, tried uninstalling and install, cant also :O
tohchr
U clear the app cache also cannot? That means should have some conflict. Did u restore from an old phone?
gonnie
2 weeks again i able to access, today i cannot :/ keep restarting
Are you able to log in if you are using hsbc app on honor v3?
