Honor Magic V3
wildpig8
Hi! Just bought a V3, after setting up i have issue with bank OTP.
The OTP message from the banks either come in very slow/late or don't even appear.
May i know do you all face this issue? Is it my setup issue?
Thanks in advance!
doki81
Thanks in advance!
having same issue...my only way is the if i know i requesting otp..i will open the bank app straight after i request otp push.
maumu
Thanks in advance!
have you two tried to 'Allow background activity' and 'Allow auto launch' in the app settings in the phone?
doki81
i didnt try..for me..i am ok with the lag as i will go open the banking app i need if i know i expecting otp.
fOreveRity
Just ordered the phone from 12/12 promo.
A few questions to check in existing user here.
1. Will the Kevlar casing with magsafe 'pop' out the screen protector, I'm looking to get a crystal screen protector for the front.
2. Base on WhatsApp F&Q it seems like now is possible to port over my ios chat logs to Android, have anyone managed to transfer it?
3. Is the android auto working or lagging, I tried other android phone for it but it seems to lagged in my car.
Computeron
1. U mean the front casing? if so... if ur sp is thick, it will lift ur front casing. will trigger ur OCD... and after u sticked the front case, n feel like removing, it will lift ur sp as well... so beware..
tempered glass not recommended... 100% ur front case can't fit.
best is and front case with glass together in 1.
2. I think that time I transferred from iOS, logs are in... just backup in WA
3. no comments I don't use.
yhw22
1st November Google play system update available now on V3.
JFYI, It is available in all non-Google phones, as long as Android 14 (if not wrong) and above. It is now controlled by Android instead of the manufacturer.
doki81
seem like honor just push out os 9 to v2 today..v3 shd be not far away.
fOreveRity
Can active user share a pic of what kind of casing / setup they use for their v3, i'm sourcing for magsafe suitable case without increasing alot of thickness in it.
Thank you in advance
Nemesismaster
Anyone got case to recommend? Look around at brick and mortar but everywhere selling Samsung and apple. My backside itchy looking for a different feel other than the original case
madhero
Got mine from AliE. I reckon one of the thinnest cases with MagSafe is Carbon Fiber cases. Not much drop protection but sure to keep scratches and scuffs at bay. Not that expensive as well. But do note that I modified the edge piece with Carbon Fiber vinyl from Japan as the original is some cheap fake leathery material that looks crappy. MagSafe is strong enough to hold your accessories and charger tho.
[/u
rl]
maumu
I can't find this from settings
sorry I thought for china phones the settings are somewhat similar (cos they're known for being aggressive when it comes to battery usage by hibernating apps that aren't active)...
idea is to allow the app to remain active in the background and/or to allow the app to launch on its own (in order to show those notifications).
that's how I handle my oppo phone to ensure I'm getting those notifications from the banks.
fOreveRity
[/u
rl]
look good, that was what i'm looking, but is the magsafe good enough as I using magsafe charger when driving hope it dont drop off.
madhero
The MagSafe is strong enough. I use it in the car as well and it won't fall off as they actually use magnets instead of just metal ring inside the case. I'm actually surprised at the strength of the MagSafe considering the case is so thin.
fOreveRity
Mind share the link to it bro, as there many variant and seller in shopee/alie
Thank you!
