Honor Magic V5
chari-men
And the curved screen makes it feel sharp.
I bought my hydrogel at a kiosk and they cut the shape to fit my V5. They had a lot of preset shape in the printer. Don't think quality is v good though, edges are starting to lift and can see dust.. maybe will try the smartdevil
Hydrogel the layer will wear off faster also need to replace quite often else scrolling not smooth...
hoks
Anyone using fitbit wif v5? I can't get WhatsApp notification on my fitbit band to work. Can any expert advice?
chari-men
I'm using Samsung watch without issues.. try to go fitbit app and see if you enabled permission for notification? And for it to appear in both phone and watch or either one..
hoks
Try to set, allow apps to run in background.
May help.
Read HWZ Forum Rules!
Thanks. I have set both already. I even set it fitbit notification to mirror my phone. But only phone calls are going thru and nothing else.
yhw22
do you get other notification in the 1st place? as me using fitbit, it since like fitbit issue, siao siao one.....song will have notification kept appearing, then can suddenly no notification at all.
hoks
Only get notification on the band when phone call comes in, nothing else.
Yes it was also seow seow previously on my Samsung, just like u mentioned.
yhw22
try restart phone or wait for next update, the notification may start appearing again. lol
