Honor Magic V5
chari-men
Regards to the question on the clock delay 1 hr previously.
I have found the issue, I stay in Bedok South area, the phone tag to Indonesia network. Usually will connect to Indonesia network in the middle of the night, and the clock will delay 1 hour the next morning.
Previously using S23U did not encounter this issue.
Read HWZ Forum Rules!
Which Telco are you using tho??
Tuakong
I was at Punggol Northshore on Sunday and it autos-switched to Celcom. I quickly disabled autoroam.
Using Simba
yhw22
this indicate that simba signal is very weak in those area where roaming signals take over it. :D
keithlim
The edges are curved that's why I didn't get tempered glass. I just put on the smartdevil gel sp, it's way smoother than stock sp. Ordered another case on shopee. I just migrated to v5 today. I updated the firmware before I start moving the apps over using device clone wireless. WhatsApp has no issues.
Can share the link of the one your bought?
It doesn't attract finger print or dust much, right?
SuperDecker
【淘宝】https://e.tb.cn/h.hsMAcQD2tOXc2Ec?tk=5wAS48QGpVa CZ005 「闪魔适用荣耀magicV5手机膜适用荣耀magicV3/2钢化膜UV软膜V3折叠屏防窥保护膜Vs外屏水凝膜全屏防摔贴膜」
点击链接直接打开 或者 淘宝搜索直接打开
Pretty good. Smartdevil screen protectors are well known for quality
chari-men
Looks good.. do u also paste for inner screen??
SuperDecker
No leh, I didn't dare to remove inner sp. I bought a casing back and front with attached tgsp and had to remove the smartdevil sp. But this case adds alot of hefty weight. Still haven't had much time to look at other casings. I'm not quite ready to leave the front without case...U guys using which cases?
https://sg.shp.ee/8vhmgT9
chari-men
Front case tempered glass also makes your screen not very responsive if not mistaken.. I pasted another inner screen protector on top of existing one.. testing so far so good..not using any case..
DeepseaG1523
Fierce! U not worried when u tear off the self applied screen protector and the not supposed to be removed one will come off together?
anizee
And the curved screen makes it feel sharp.
I bought my hydrogel at a kiosk and they cut the shape to fit my V5. They had a lot of preset shape in the printer. Don't think quality is v good though, edges are starting to lift and can see dust.. maybe will try the smartdevil
SuperDecker
Actually surprisingly the front case tgsp has been good. It's smooth and sensitive. Initially, I didn't remove the smartdevil hydrogel when I use the front case with tgsp but it was squeezing tight onto the hydrogel that I had to remove the hydrogel and just use only the front case tgsp.
Maybe after a while I will remove the front case and use smartdevil hydrogel again. The weight is quite heavy but it offers solid protection which I feel very assured. Lol
chari-men
No sensitive difference compared to smart devil?? Hmm maybe yours quality better..
