Honor Magic V5
nuscape
ok, you are right, i took out the cable from my v5 box and try it. i can't get any 50w wording for the wireless charge, it only show supercharge. comparing the cable from v3 and v5..seem like v3 cable is thicker.
good to know. I thought I got a lemon set.
perhaps honor is not being honest again and tried to cut corner giving us sub poor cable or not the same as previous version.
Read HWZ Forum Rules!
nuscape
Smart battery capacity is 'enabled' by default. Does this mean full charge is actually only 80% although it is showing 100% ?
So in order for us to test the full capacity of 5820mAh we have to turn off this setting?
Coming from Oppo and Samsung, with this similar feature enabled, the battery will show 80%, not 100%, so i won't get confused.
chenaz
Just look for those cable and adapter supports SCP or FCP. SCP preferred as SCP is faster and newer.
doki81
this one on v3...very buggy..sometimes will have warning said it won't full charge and stop at 80%..sometimes will not appear. i think v5 also having this same bug :(
nuscape
you mean by right it should stop at 80% when switched on?
now our V5 always go all the way 100% regardless switch on or off what, right?
yhw22
if you all don't want it to stop at 80% during charging, turn off the smart charging.
nuscape
even if we turn it ON, V5 does NOT stop at 80%, it will go all the way to 100%.
The setting won't do that it is supposed to do. it is a bug.
For some we want it to stop at 80% eg. plugged in to power for longer period using desktop mode, etc.
keropok8
Planning to get a 2nd hand Honor V5. But the shop said warranty is tied to original owner not the phone.
Anyone has any idea about this?
Anyway for new honor, does the warranty start once you on and activated the device? Thank you!
chari-men
Tied to serial number more likely.. I registered my warranty with eplanet even tho not required.. starts the day you receive the phone if not wrong ..
keithlim
Does Honor Magic v5 have the AI image to video function? I know this is available in Honor 400 Pro.
keithlim
Have but...3 times free trial and then need to pay 80 cents per generation ☹️
Thanks! Is that 3 times a day, or basically the whole lifetime?
Side topic, I just noticed the Honor Workstation is now available on Mac appstore. Good for wireless file exchanges.
chari-men
You ended up getting V5 not vivo fold 5 ah??
keithlim
I got the Vivo XF5, used for 2 days and don't like some minor annoyances here and there. Plus I find that it isn't much better than my Honor v3. So trade in at a loss for the Honor Magic v5 at litemobile.
chari-men
Lai share some of your reviews for Vivo Fold 5, the good and the bad lol ..
petricnah
Regards to the question on the clock delay 1 hr previously.
I have found the issue, I stay in Bedok South area, the phone tag to Indonesia network. Usually will connect to Indonesia network in the middle of the night, and the clock will delay 1 hour the next morning.
Previously using S23U did not encounter this issue.
