Huawei Mate 10
Synchroniza
Woooo just bit the bullet on the blue mate 10 pro. Gonna spend the night setting up the phone.
Any tips from iphone to Android how to Xfer? :)
TIA :s12: :s12: :s12:
SExiao
Bro, any bro compare the music output (e.g Spotify) from Iphone and Mate 10Pro??
Note 8, S8 base on my untrain ears does not sound better than Iphone... prob due to Iphone having stereo sound??.... :s8:
knave
You referring to speaker output? Samsung phones only has one speaker at the bottom, thus sounds Abit mono. iPhone 7/8 and Mate10s uses the top speaker to output audio as well. You'll definitely get a better quality output, not just in video/music playback, but gaming, speaker phone, ring tone output etc all gets a major boost.
WWE_Fan
Been using Mate 10 for 2-3 weeks. One gripe is I can't move apps to SD card.
This internal is only 64GB and now I have 40GB left after installing some apps.
I have a 256GB SD as well. Any workaround?
leonard87
hi guys, anyone of you playing games like phantom chaser or dragon spear? or maybe any other game that are able to launch on other devices but just not able to launch on huawei?
chris24
Just set up my M10P blue. Realised I cannot turn on Ok Google detection at all. Anyone having same issue?
WWE_Fan
Try posting in the game page on android playstore.
when I first got the phone, clash royale and wwe champions was not compatible until 1 day later.
I got the phone on launch day at singtel.
leonard87
u mean on the review page of the game? i was thinking why my game can run before an update and after it, it cant run at all..
deckcard
Did u check the apps setting page under storage? Not all apps support installing to external storage tho.
Another suggestion is to move pictures and videos (big file size) to external storage (or to cloud) so u can free up ur internal storage. You can also set the camera to default to external storage in the camera setting page
kirium76
Just finished setting up mine too. With the electroplated soft TPU case. Very snappy performance. Hope it will maintain for the next 18 months. :)
Sent from LGE LG-H990 using GAGT
WWE_Fan
that's what I did for wwe champions. android got so many versions and models. may be useful to update the developer
WWE_Fan
I already set to default for all photos, videos and downloads to go to SD card. what's left are apps. I guess it's a limitation for phones with external storage.
before this I was using S6 edge with internal storage. this gave me a bigger storage to experiment new apps. with mate 10 I have to be selective on what to download.
deckcard
I was doing this on my old phone and it was working fine. But now I cannot even turn on the OK Google detection function under Google setting in M10P. Can only launch Google assistant via touch and hold the home screen now..
www.droidviews.com/force-ok-google-detection-screen-off/
It should still work when screen is on tho, did you check the Google settings? Re-setup the ok google detection again
