Huawei Mate 10
Zon
what type of messages? sms? whatsapp? wechat? line? viber?
try "manage batch manually" under launch.
WhatsApp.
Already tried. But seems like once app closed. It can not run at the background.
Example when I closed all apps. My WhatsApp web version will say cannot communicate with phone.
Mate 9 was ok though.
My WhatsApp messages will only come in when I wake or unlock the phone
Zon
Agree with you 101%. Started using Mate 9 since last year. Changed to P10PLUS and now to Mate 10 Pro. All apps works well for me..
No prob for p9 and mate9
But mate10 p I tried this app. Mixcloud. It keep restarting the app.
xblue8devilx
WhatsApp.
web version? you using browser such as chrome?
MichaelTan
WhatsApp.
this problem can also be solved:
Whatsapp not receiving messages in real time because of improper installation of Google Play Services. Just go inside and enable background data for that.
Settings : apps and notifications : apps : Google play services : data usage :
enable mobile data, background data and roaming data
Do the same for Whatsapp.
Zappalapa
what about wifi issues?
been experiencing it since day 1.
will load and load and tell me cannot load despite strong connection to home wifi. happens erratically throughout the day.
previous phone can load everything when I put it side by side mate10 pro.
MichaelTan
switch off Wifi+ and just use normal Wifi
Also, Wifi is very prone to interference. Intermittent wifi connection issues might mean you have interference. If you have control over the wifi, what I'd do would be to disable 2.4Ghz on the router and just exclusively use 5GHz.
Zappalapa
Thanks for replying!
I don't switch on wifi+
I understand the wifi interference part, but this has never occurred with my very old phone (galaxy note 3) but happens very often in mate10 pro.
could it be due to faulty wifi module/component inside the phone? or could it be software issue? I have seen some people reporting the same issue on the net/local fb group.
MichaelTan
In my experience, if Wifi works, it works, it don't work halfway. If it even works sometimes, then there's something wrong with the Wifi. And most of us have excellent wifi, so the explanation may have to be probed further.
If you have an old router, or haven't updated the firmware in some time, consider this: the Mate 10 uses Mu-MIMO Wifi, it has multiple radio for Wifi at the same time to achieve double wifi speed compared to the Mate 9. Some old routers had the ability to support MIMO but the support was defective and many devices which used MIMO had intermittent connection issues.
The Galaxy Note 3 you have did not support MIMO so you wouldn't be able to expose the issue. One way to find out is to go to your office and connect to their enterprise Wifi (if any) and see whether you have the same issue or not.
If office doesn't experience the same issues as your home, the only suggestion I have is for you to fix the router's MIMO issue, by swapping the router for a newer one, or by updating the firmware see whether it's of any help.
Promethus
Not getting notifications from apps like carousell and ebay on my mate 10 . Any ideas?
deckcard
A few things to note when it comes to notification from WhatsApp, Viber, carousell or whatever messaging software
1) enable autostart for the apps
2) lock the apps in your recent apps list
3) disable any battery optimization that you can find in the battery settings for the apps
4) check the apps settings have notification enabled (usually already enabled by default)
maumu
how to enable autostart for apps? i'm having the same problem with my Garmin Connect app which requires Bluetooth connection between the phone and my watch. everytime i close the app, the connection also kena cut off. not sure if it's got to do with the Bluetooth LE (low energy)...
can autostart but run in the background or not? i don't like to see so many app windows...
Zon
Both apps already enabled by default for data...
I trying one more setting. Manual manage for Google services on top of WhatsApp manual manage.
Promethus
I've tried the manual manage too, didn't work.
Didn't face this issue with the mate9....
Promethus
have you already went to the launch menu and disabled automatic handling and chosen to enable all the manual controls?
Yes. Tried to uninstall and reinstall again also nothing.
Have to depend on email notifications now.
xblue8devilx
i have this issue on my carousell previously, even after manual control. But after update the app from playstore, everything is working fine now.
HuatKway
Hmm this is weird. My Bluetooth jaybird disconnects randomly while jogging. Device says connected but it just plays via speaker suddenly. Had to reconnect to get it to play via jaybird again. U all having same issue?
