leon0079
- Oct 7, 2009
Nice how much is it? Me thinking of getting one tooreceived my huawei watch.
Sent from HUAWEI Mate 10 Pro Blue using GAGT
You have to go to Special Access -> notification permission and grant Android Wear. Took me a while to figure this out.
Apps and notification-> apps -> settings > special access > notification accesshow do u get to here?
To those who wish to lock screen without pressing button and work with fingerprint unlock, add the lock screen widget to ur home screen.
Sent from HUAWEI ALP-L29 using GAGT
Yeah it's damn difficult to find. Lol
But i get "app not install" when i try to add that.
The lock screen widget only works on stock launcher,won't work if you are running 3rd party launchers
Facepalm. Lol. ThxUse the search bar.![]()
Got it. Thanks bro... Managed to get it working...The lock screen widget only works on stock launcher,won't work if you are running 3rd party launchers
you might have chosen unsupported language. Just choose English UK or US for now. English (Singapore) is not yet supporting OK Google .Just set up my M10P blue. Realised I cannot turn on Ok Google detection at all. Anyone having same issue?
settings : system : developer options : force allow apps on external storage (enable)Been using Mate 10 for 2-3 weeks. One gripe is I can't move apps to SD card.
This internal is only 64GB and now I have 40GB left after installing some apps.
I have a 256GB SD as well. Any workaround?
Ok google detection should work right out the box. Have you disable any google stuff? Also check your language setting, make sure you are in English
Hi guys,
Just dropped by Handphone Inspiration over at Marina Square #02-217A and got a good deal tempered glass screen protector + a spigen lookalike carbon case for 12.90 and surprisingly the quality is quite good. I'm kind of glad right now I made the trip. Worth every penny spent. Oh and they're on Carousell too. Dammit was looking for these stuff for quite some time now and finally got it... OK me gonna go grab Paulaner now.
any pic of the carbon casing? for m10 or m10p?
Now I have e 2nd best alternative of LG to knock knoc.
It won't stick ie greyed out. It reverts to grey even after sliding to blue.
It's not working.
