Huawei Mate 10
DaveMusic
I had been trying to upgrade OS to 128(C636) after reading about the newer version. Problem with Vm ware boxer forced me to try with MY SIM Card, and it works immediately!
Upgrade done and my VM boxer apps is working perfectly now.
So far can’t feel any improvement other than a working boxer apps
knave
So far can*********t feel any improvement other than a working boxer apps
You should use Nine email app instead. Better.
maumu
Pretty good for the 3mm jack.
Funny thing is the Hiseten sound effects only start up if you go into Settings > Hiseten.
It doesn't auto turn on when you start your music.
Speaker wise not very loud but definitely better than non stereo ones like Samsung.
am glad i'm not the only one who noticed this too. hope they will fix it in the fw update.
but seems like they're pretty slow with rolling out the fw updates... :\
aardvarkgeo
Just moved to Mate 10 Pro from Mate 9. On M1. What is the latest firmware? I am on 119.
Sent from HUAWEI BLA-L29 using GAGT
haylui
Guess SG telco are slow in providing firmware updates..119 here as well. SingTel set.
progene
Actually the fw update quite fast le. Bought in Nov. So far already received 2 update.
The Nov Android Security Patch and the Dec Android Security Patch.
Now only Jan. I expect the Jan patch to come early Feb.
Sent from HUAWEI ALP-L29 using GAGT
DiCaprio
Hi guys, any way to detect what is keeping my M10 Pro awake so much? Battery life isn't as good as it was out of the box. Location on, mobile data most of the time. SOT 1h 20min thus far.
Sent from Tomorrowland using GAGT
haylui
Which firmware version?
Mine also feel the same, after update once then the battery life is not as good..
haylui
Maybe yours are not bound by telco...
aardvarkgeo
The case and screen protector that the Mate 10 Pro comes with is actually pretty good quality. Better than the Mate 9 I had.
Synchroniza
Haven't updated my phone since purchased...
I'm afraid update then batt life not good. Loving the batt life as of now.
BTW not sure if asked before. Those hotel WiFi how to connect? On my iPhone they will bring me to the hotel log in page. But for my m10pro nth pops up.
eyz
guys, which browser do you all recommend?
am currently using chrome and find it faster and less ad than dolphin which I used previously.
however I like dolphin features where most of the commands are accessible from the bottom and side of the screen, so I don't have to use my other hand.
furthermore, the dolphin always crashed. it was still working well in my nougat v20.
xtemujin
After updating to the Hi App V8.0.1.301 on the phone, the Connect to Computer is now on another app HiSuite.
HTH.
knave
Normally I would launch the browser and try go to Google home page. It should auto redirect to the login page
