Huawei Mate 10
tcyntu
guys, which browser do you all recommend?
am currently using chrome and find it faster and less ad than dolphin which I used previously.
however I like dolphin features where most of the commands are accessible from the bottom and side of the screen, so I don't have to use my other hand.
furthermore, the dolphin always crashed. it was still working well in my nougat v20.
I use Brave Web Browser. It is a fast, free, secure web browser with a built-in AdBlock.
leon0079
Anyone keen to buy my new nillkin nature brown tpu case?
Sent from HUAWEI Mate 10 Pro using GAGT
lemonpie
Hi!
Just got a M10 porting over between telcos, so far so good.
Noticed that even though I got all notification sounds off, Instagram still has a shutter sound going on. Is there anyone else here with the same symptoms?
leon0079
Got photo?
HuatKway
Just checking is it safe to do manual update of firmware? Still stuck w 119. Wanna see if it resolves the Bluetooth issue. The ota is really slow..
HuatKway
Was trying firmware finder based on forum's suggestion. It kept saying its not approved for installation when using imei to check. Any idea why is that so? Btw latest version is 131.
Ahh.. I use the change dns setup and managed to get it downloaded. Only problem now when I click update it says server temporarily unavailable -_-
HuatKway
Finally found out how it works. 129 and 131 not signed and hence can't be installed via firmware finder. Tried 128 and it works :)
KeYoKe
I got transparent nillkin nature tpu and nillkin tempered glass for mate 10 pro (1 of the better TG for mate 10 pro) extra. Any bros keen to buy let me know
watzup_ken
May be you should try searching to see the comments or feedback of those that have installed the new firmware. It seems the Bluetooth spotty connection issue is common for Android, even on the Google Pixel 2 phones.
hermes76
Is the TG a full coverage kind? How much u letting go?
iCuteCube
Problem - If you are navigating say Facebook, or Instagram or any other App, once you received a whatsapp msg, from the top there will be a drop down on the whatsapp msg. Anyways to disable the "drop down" from the top? Appreciate display the whatsapp sign on the top for new messages, but do not want the "drop down" kind of notification. Been toggling the phone settings for awhile but still cannot disable that "drop down" effect, anyone facing similar issues?
jtv_tm
Just wondering if anyone noticed that the battery drained significantly faster after the latest patch?
Sent from Kingdom of Bhutan using GAGT
DaRRenLieW
Hi guys wanna check how does the warranty work ? Can’t find on the website to register my phone but when I type my imei it show the expire date .
Have anyone successfully went down for service or repair without original receipt , only show them thru the warranty status page ?
I do have a soft copy of the original receipt thou
