Huawei Mate 10
garth6
have you reset your WiFi?
test while not reseting wifi, get the msg
test while reset wifi, still get the msg
off the vpn from the app, it says im not allowed to update the firmware, then phone deleted the update.. yay~
HuatKway
The key thing for server unavailable is because ur vpn is connected. Drag down notification and disconnect the vpn then click install again.
For ur case ur imei/firmware is not approved for installation yet so it won't pass. Only select those which is approved
garth6
Thanks for the clarification! will go try again~~
Zantesuken
tried it. didnt work as well
watzup_ken
hi bros, i have no idea what i did but the background turned to black for certain screens like settings and gallery. see image.
how can i get back the previous white one? tried looking under settings, display, but can't seem to get it back.
appreciate any help!
Are you using Mate 10 or Mate 10 Pro? If you are using Pro, then better stick to the dark background as it helps with conserving battery.
HuatKway
Explain abit: u may find Alot of firmware from 119 - 132 but not all is approved. Previous 131 for mate 10 pro was not so u can't installed. But 132 was just signed and approved. I'm guessing 131 could be for other region sets or it could be some internal trial :)
Cyberboy128
Just got my M10P. Firmware at 119.
Is there a newer version? How to update?
Seems that this version does not support voLTE.
charleslin
M10 non Pro also 119 here.
I think is either you use the Firmware Finder app to find the newer firmware or need to insert other countries SIM card in order to trigger the newer firmware.
Local Telco is still at 119.
garth6
hmmm im on starhub, m10p, v119, 132 non IMEI says allowed but encounter the server temp unavailable error
pawn_king
is this phone worth buying still?
seems an unusually high no. of resale (on carousell) and this thread discussion mainly on problems/bugs/OS issues.
Zantesuken
its still a good phone in general. i myself is only pissed with the software as in the updates are seperated . some of us can update some cannot. etc etc.
Ruriel
I'm loving its camera. Other than that, just be more mindful of which apps you want to be kept awake and take steps to ensure they don't get killed in the background. Battery life is more than decent (just don't expect fantastic life span if you manually keep many apps running the background for widgets/push to work). I don't mind if I'm not having the latest updates or what not, so I don't have the problems of not being able to update to the latest version, since I don't bother with it for now.
KeYoKe
Every phones got their pros and cons and every software be it iOS and android has their own bugs.
For me, im enjoying the snappiness and battery life of the phone. So far i dont have any complaints. I even bought my wife a pink gold today for her birthday and valentines present. Camera of the phone is great too, just point and shoot and you still can get decent photos
I am at 1 day 7 hour on battery with 2 hours 10mins SOT, i still have 59 percent batt remaining
