Huawei Mate 10
knave
I tried the Firmware Finder but all not approved for my IMEI le, is that normal?
Choose only the Full Ota.
If it's still not approved, then you have to wait a while. Probably not yet granted for your phone. But I presume should be within the next few hours or days.
haylui
really weird.
why the difference is so huge. you're using 119 and haylui is using 128.
I'm using 126. haha
I went back Malaysia using Malaysia sim card and OTA pushed 128 to me.
People in SG also can insert Malaysia sim card and get the 128.
haylui
official singapore fw is at most on 119.
those who got the later version is definitely using FF to update.
myself is on 128 too haha
Also can use foreign sim card to retrieve later version if the country of the origin of the sim card already pushed out.
charleslin
You guys using the default screen protector or removed it and change to third party?
Any good tempered glass for non Pro to recommend? Nowadays a lot of types, that time I tried one for my Pixel 2 XL, the edges touch responsive is CMI lol.
charleslin
Hi, knave. How come I use FF try to install 131, pop up to me not approved after IMEI checking.my one is 10 non pro .
I think they approve slowly by batches.
Technically the firmware is ok for our model but they segregate by IMEI slowly.
Mine is also not approved for all the different firmwares except the current 119 one.
GYY5450
I use FF to check , found BLA_L29 B 132version approved for my non pro installation. Very wired.
Can proceed install ? Any advise
charleslin
There's 132 for you? I only see up to 131 le.
Non Pro here as well.
Anyway once it's approved, you can install.
But I think you'll need to change the DNS to be able to get the download prompt, after which you need to change back to your normal DNS when it's downloading.
Then it will just install like normal once it's done downloading.
That's what I know looking at the previous posts.
knave
It's BLA-XXX, so it's meant for Pro.
Better Dun try if yours is non pro.
Cyberboy128
Ran FF on my M10P. Listed 129, 131 and 132.
129 and 131 - not approved. Tired to install, failed.
132 - shows approved. Installed successfully :)
Now finally I have voLTE enabled.
CS0287
Anyone tried the setting "stereo+" under sounds ?
What's the difference? I can't really tell... Hahaha
machocheng
Code:
Hi, anyone migrated from Samsung Galaxy ecosystem to the Huawei Mate 10 Pro? Thinking of making the leap of faith but unsure about Huawei phone interface.
Thanx.
Rubick
Code:
Thanx.
Still a android afterall.
You can always change a launcher, if the huawei launcher does not suit u.
Changed from a note8. Happier with the flatscreen and awesome batt life
