Huawei Mate 10
symbiote28
try download hisuite on your pc first and update it to latest version before plugging in ur mobile phone. it works for me that way
already have hisuite installed on my pc. even went to the extend of uninstalling and reinstalling it since it was already on the latest version :(
chameleon20
Set up error for gmail in Mate 10 pro Email app
Hi, I just got the Mate 10 pro today and having a hard time to set up one of my gmail account in the Email app.
I have the same error initially on the other gmail account but after I went to gmail and allow less secured app and it worked.
But despite doing the same for another gmail account, same error keeps showing and prompted POP/IMAP may be disabled.
Anybody encountered this issue and able to resolve it?
Thanks to share...
Fookai
Hi guys, just got a mate 10 pro and took a video today on my phone mount while riding a bike. Due to the vibration the video came out very wavy, like got no stabiliser.
Previously took a similar video with my nexus 6p but it was smooth with 0 wavy thing. Anybody know if theres any option to stabalise the video? Or the phone got no/lousy built in stabiliser?
Thanks!
Sent from HUAWEI BLA-L29 using GAGT
shairi18
after u plug in to your pc > give permissions on your phone (tap on yes) once promted > wait abt 15 secs > un plug the usb cable from ur phone > plug in again. see if it works, cause it works for me that way. make sure hisuite is running throughout the entire time. if still cannot then try on a windows 7 pc. mine is windows 10 and i encounter same problem as u but that method works tho.
CS0287
Thanks to share...
Did you enable imap for your Gmail account?
Did you try using app password for your Gmail account instead of normal password?
eyz
the same thing happened to me.
I think the phone simply had lousy stabilization.
Edidlt: Just checked that stabilization is available in non high res and framerate video.
Thanks!
rubber33
Hi guys, any other way to wake the phone other than the power button and finger print sensor?
Fookai
Yeah think the stabalisation like non existent, cause I was videoing in stock settings which shld be 720p only. Meaning stabalisation is on, hopefully is software bugs and can be fix with an update
chameleon20
Managed to resolve it after using computer to change the “Allowed less secured app” in gmail account.. I thought I have enabled on Chrome in the hp but seems its not captured.
Thanks
r0_ger
means it has been sitting in the shop for months for it to drain till 0%
Just recontracted Mate 10 ytd. At Telco unsealed also 0% and they charge with generic charger... damn slo. Gave up and pass to the in store Huawei promotor. He mentioned that this is a batch issue. Factory didn't charge up the subsequent batches. They have feedback it le... But can't do much with those already shipped with a flat batt.
So it's not the case that the phone was left turned on till flat.
Skyy
oh really? I recently bought the pink version and it was charged up to 60%.
