Huawei Mate 10
carboy00
Good time to get a Mate 10 now? $598 now without contact.
I think it's a good deal. Esp comparing it against Honor 10. ~$20 more, higher screen resolution, Leica cameras, smaller internal storage but there's microSD card slot.
Sent from Xiaomi Mi 5 using GAGT
Yuripa
Using a mi max 2 now, finger itchy after seeing it go for only 589 lol.
CrispyPeddler
depend on your need. if you like huawei phone, then i think its good time to get it
compare to the new p20 / honor, its almost the same..just few minor differences that are negligible.
Audiology93
Yes. Very good price.
Yeah Honor 10 makes no sense lol. Lousier display, no microSD slot and smaller camera aperture. Even the View 10 is a better deal than the Honor 10.
Sent from HUAWEI MATE 10 using GAGT
watzup_ken
Anyway, after using this phone for more than 6 months, I finally ran into some trouble with it that was quite annoying. The tethering feature on it simply won't work for me. Was trying to connect my laptop for like 15 mins before I gave up. Laptop detects the phone when I enabled tethering. However, it keeps trying to authenticate after inputting password for a few times, then it will just suddenly stop authenticating and go back to showing as secured connection. Never experienced so much hassle and instability tethering on a phone before.
zaizai66
Hi guys i just got my mate 10, any idea how to transfer my things on iphone to my new mate 10?
HuatKway
Been tethering frequently without problem..
OutBreak
Huawei is crazy.. Why launch so many phones that looks almost the same in specs..
knave
U have to make full iPhone backup via iTunes
Then download ibackup viewer to browse and extract stuff like Sms, WhatsApp, photos.
Then buy wazzap migrator to port WhatsApp.
knave
Probably due to windows update? Try remove the ssid from your laptop and re add again. And change your phone ssid pwd.
Luna99
Anyone facing the BT device getting cutoff while your device still streaming music? Like suddenly switch over to phone speakers. Any way to resolve?
My build is ALP-L29 8.0.0.132
bratpig
Waste more battery juice? Lol. But I think only affects gaming
LOL. Don't really play games nowadays
But thought that there's no need to be too anal on the battery
After all, I buy a phone to enjoy. Not to be a slave to it
bratpig
Everything can be transferred using the USB cable or pc
But you need to buy the apps to transfer whatsapp
Just buy the suite and you can enjoy unlimited change of phone from ios to andriod and vice versa
HuatKway
Mine on 135 still faces the same problem. So it's not resolved. Think it's common across android devices
