Huawei Mate 10
knave
Install and not much diff.
The raise to wake not bad. Haven tried the face unlock.
CrispyPeddler
Mate 10 or mate 10 pro?
This raise to wake is new feature?
new feature to mate 10/pro i think. other phone have it already.
its good for those using mate 10 pro coz as of now there is NO way to wake phone without pressing the right-side button
knave
Non pro. Yes new feature introduced in this update, to pair with the face unlock. If you don't use face unlock its fine to enable this so that you can see your lock screen when you raise up your phone.
CrispyPeddler
the update only for non pro? :(:(.
yea. the lock screen looks so nice but barely able to see it
hermes76
not sure how to do it. :s22::s22:
Use the in-app proxy to trigger the normal download, and let the phone download itself.
Flow
Press the proxy in app or something, it will install a VPN on your phone.
Just go and search for update as per normal from settings, will show you the available update, download and pause it once it's downloading.
Pull down your top bar, and disable your VPN.
Then resume download as per normal.
The VPN is to allow your phone to find the new firmware, but needs to be disabled prior to installation.
Sent from HUAWEI Mate 10 Pro using GAGT
