Huawei Mate 10
CS0287
I just realize the new app isn't compass... It's "app gallery" that you can't uninstall or disable.... haiz....
Audiology93
Hi mine is still 134. What is FF?
Sent from HUAWEI BLA-L29 using GAGT
Firmware Finder.
Sent from HUAWEI MATE 10 using GAGT
Audiology93
fuuuh...finally got it to work with firmware finder! love the new feature! ok, for guys that are totally new with this like me, i try to explain step to step method:
1. Download in playstore "Firmware Finder for Huawei"
2. Click the app and it will auto detect your phone. Click your phone model "BLA-******"
3.Find the firmware that end with B138 (i did it with 752mb OTA-MF) and click in
4. Check firmware access and check availability. it should mention firmware approved.
5. Click download and download the 3 files
6. Once download complete, go to your wifi (whichever that you are connnected) and click modify network > show advanced network > Proxy > manual. Key in the following:
-Proxy hostname: localhost
-Proxy port: 8080
-Click saved
7. Go back to the firmware finder and click "In-app Proxy"
8. Go back to phone setting>system>system update. At this point the new firmware should pop up.
9. Click quick update and pause it. Disable the "In-app Proxy"
10. Go back to your wifi setting and modify the network proxy to "None"
11. Then back to system update and press continue. Enjoy!!
Instructions for who trying to update to 135. Many thanks to CrispyPeddler for the guide :)
Extremme
Ah nice job there. If I don't use firmware finder, I will have to wait for the phone to prompt me in future?
Will it brick the phone?
charleslin
Liking the face unlock so far, but dislike the "bug" it brought.
Now cannot expand the notifications in lock screen already. Like if I have 5 msgs, I want to see them instead of unlocking my phone and go into WhatsApp, I cannot open up the notification box, only show the last.
Audiology93
I've updated mine. Shouldn't brick ur phone since its an official update(just that we got it faster).
Extremme
Updated mine. Works well. Thks guys!!!
BTW where can I find details of what are the improvement made for B138?
haylui
Soon Huawei will release a new version with GPU turbo function.
tayweiyang
Just curious, anybody having charging problems with the original charger?
1. Supercharging upon connection but switched to normal charging
2. States charging, but not actually charging
Went to service centre 3 times already, not fixed at all. Sigh..
CrispyPeddler
u mean new firmware? woah. cant wait!
Still waiting for that upgrade to emui 8.1 and improved camera app.
any announcement what will they do in emui 8.1?
how to see if its supercharge? i normally just put there and ignore it..around 50 mins from 10% to 100%
donetus
hi guys,
I'm eye-ing to get this phone as replacement for my iPhone 7 Plus. However, I'm still torn whether should I get this or the Pro version.
What's your input on this?
Audiology93
Hope it comes soon. Can't wait to chiong more PUBG :s13:
hi guys,
If you're fine the way iPhone works(no microSD slot, no headphone jack), go for the Pro. But if you need microSD slot and headphone jack then Mate 10. Another thing is the location of the fingerprint sensor. I personally prefer the design of the Pro but can't justify paying $200 more for the same performance :s13:
Mate 10 is one of the best value for money flagship.
donetus
Yeah, that's the thing though. I don't like the part where I'm restricted with only 128GB.
I'm also taking in consideration how good the camera is. Is it good in terms of low-light? Been reading several sites and they're giving mixed reviews.
