Huawei Mate 10
OutBreak
The auto brightness on my mate 10 (non pro) seems to go crazy sometimes.. It will turn down my screen brightness until its very dimm. Anyone have the same problem?
Shib
For my case, I find it did not turn down enough...
Sent from HUAWEI MATE 10 using GAGT
CrispyPeddler
yea. there is still no fix to this issues. even if you untick the autobrightness, it will still auto adjust for you...so called power of "AI"
very annoying
Audiology93
Yes. Super annoying when I'm playing pubg and tried to set the brightness to the max but it's not bright enough...
FireHobbit
The firmware upgrade is really a hassle. The OTA is not.being pushed down to Singapore Telco to us.
From Mate 10 Pro
viceroy666
I could not get the update in Singapore. Now I am in Bali and got the update without FF. Happily updated and using 138
charleslin
Btw is it Android issue or Carousell?
For example I dont get notifications at all, until I open the app then I will know I have messages like 2 days ago. Sometimes it will notify sometimes it doesn't.
WhatsApp Email all works fine though.
CS0287
I think it's Huawei.. they only keep notification of certain popular apps.
I also have the same issues with carousell on my m10pro .... I don't have issue with it on my previous Nexus 6p.
Bumblebee Man
Bros. Just got myself a mate 10 pro. I noticed that wallpaper doesn't scroll even if I enable scrolling. Is this a known issue or any way to resolve?
Sent from HUAWEI BLA-L29 using GAGT
donetus
I dont' have that issue on my phone. I'm not sure if there's any difference with Huawei's Top Apps or manually getting it from the Playstore.
Btw, I have a question. I recently got a Mate 10 and I noticed that the battery drains too fast. It was running at 65% around 10AM and before 2:30PM is was already at 35%. I'm running on v8.0.0.132(C636).
Do I need to run an update? If yes, will I get it from Firmware Finder? I've tried checking the availability of .136 but it says that the firmware is not approved for installation.
Ruriel
I am still on 132 on Mate 10. Batt no issue - I plugged out the charger on Sunday night 11pm, and as of today 2pm, it was still at 55%... Usage on Monday was minimal yesterday though - some web surfing, chatting on WA/Telegram, and reading ebooks.
Audiology93
Its a Huawei thing. Too aggressive with the power management. But I dont have this issue on carousell app, only Gmail.
Sent from Google Pixel 2 using GAGT
Audiology93
Try 135 instead of 136. I updated mine to 135 using FF.
CrispyPeddler
Woah..how u last 2 day. Mine full charge 12 midnight...the next day 10 night is around 10%?
donetus
I managed to update it to 135 so I'll try to monitor the battery status. Btw, do i need to do some calibration after that?
I'm wondering, how come Huawei's Cloud service is not available when I try to access the Gallery?
Is Huawei online services good or should I just go with Google in terms of say, photo back ups?
watzup_ken
I think the notification is a little spotty. For Gmail, Whatsapp and Carousell, I noticed that the notification don't always work. I had the same issue with Carousell, but it doesn't happen all the time. Some days it works just fine.
watzup_ken
I can confirm that the battery life is quite impressive on firmware version 132. 2 days is doable for my case too. I noted after updating to 134, the battery life seems to take a hit. However it is still better than any of the Android phones I used to date and mind you my phone is already more than 6 months old now.
charleslin
135 seem to be a bit more draining for my battery usage as well, as compared to 132.
Disabled raise to wake since it was getting a bit annoying.
M10 non Pro.
But still good because of the huge battery but the overnight drain seem to be higher now.
Audiology93
I didnt calibrate mine. Works fine.
M10 non Pro.
I'm loving the raise to wake + face unlock :s13:
donetus
After upgrading to v135, I've decided to perform a factory reset and installed the apps that I needed. The phone was idle from 2AM until 6:30AM and it was still at 100%.
As of this writing, my phone's still at 76% which is performing much better than the previous build.
.. and i'm liking the face unlock feature.
