Huawei Mate 10
Shib
The face unlock is draining a lot of battery?
Sent from HUAWEI MATE 10 using GAGT
Zon
Any good USB c earphones to recommend for mate 10 pro?
I keep waiting for creative the new dongle to be out... But hand itchy now
donetus
is anyone running on build 134? I wanted to check if 'OK Google' can wake up the phone. It was working fine on build 132 but doesnt work on build 135.
nope. from 6AM until now, my battery is at 60%.
Zon
I recall they changed it? OK and hey was changed.
"OK Google" No Longer Needed Before Everything You Say To The Assistant. Here's How To Set It Up
OutBreak
Don't agree to the T&C when first run the app. This way, it would not use any resource.
Yes, agreed that it's a useless app.
Yes. I reverted back to the default version and did not agree to T&C. Huawei can collect more data from you through Appgallery if you agree to it.
Shib
How to revert to default?
doodlebob
Hi all, any mate 10 (non-pro) users out there facing issue with the call quality ? ie. call recipients hear my voice as muffled, too soft.
Have tried the following:
- disable VoLTE
- both Whatsapp call, normal call are facing the same issue
- recorded audio without issue, voice is clear (don't seem to be hardware side)
Currently running firmware version 135. Phone has not been dropped or subjected to water.
Have checked around online, seems to be an issue with the AI interfering with noise cancellation but unable to find a solution.
Seeking your kind advice here before heading down to the service centre as a last resort.
Thank you!
Audiology93
- disable VoLTE
Thank you!
No issue on mine. Maybe u can try a factory reset 1st before heading down to service centre.
watzup_ken
- disable VoLTE
Thank you!
Did you test it out yourself, i.e calling another phone to test? I am using the Pro version, but I have not heard any feedbacks from people I called saying its muffled. I doubt its the AI causing it.
SuperDecker
On 138 singtel and whatsapp notification is lagging. All my WhatsApp messages will appear only when I use the phone. Shouldn't have updated to 138. Lol
Shib
The face unlock seems to drain a lot of battery. My battery is ok once I stopped using the face unlock.
doodlebob
Have tried resetting twice, unfortunately didnt work. Thanks for sharing anw!
Yep, have called via 3 other phones and all had the same effect of the muffled sound. It seems like quite an isolated case as I can't seem to find related cases. Thanks anw!
Seems like I have to head down next week then.
CS0287
Does anyone experience 4g connectivity issue ? Recently when the signal is clearly showing 4g but I just don't have any data flowing in... And it lasted quite awhile .. don't know if it's Telco issue or the software issue ......
And my screen sensitivity is dropping... Keyboard has to tap much harder to register the tap..
I am on 138 mate 10 pro
