Huawei Mate 10
KYLee
Anyone playing brawl stars on mate 10? I was playing it just fine on my s7.. Just got my mate 10 and the game wouldn't load!
Fendi37
Mine stuck at "connecting server"too..I'm using mate 10 pro
Sent from HUAWEI MATE 10 PRO using GAGT
donetus
Im using a non-Pro and 132 really drains the battery fast. Noticed it when I acquired 2 phones running on the same build.
I am using a Mate 10 Pro and I think it is the other way round. Battery life was very good with 132 and it declined after I upgraded the firmware.
Anyway in both cases, the battery life is still good for my use case. Nothing to be concerned about.
watzup_ken
Anyway it doesn't matter now since the battery seems to have improved after you updated the FW.
KYLee
guys, any recommandation for chargers that can charge as fast as huawei's super charger? their original quite expensive!
Shib
The super charge is a Huawei technology. At most you can do QC2.0 fast charge or so... Anything else will be slower.
Sent from HUAWEI MATE 10 using GAGT
KYLee
found some sellers on aliexpress selling the huawei super charger.. dunno about its authenticity though..
Audiology93
Can try getting a USB PD charger with 9V.
If the USB PD charger is not equipped with 9V voltage output, fast charging will not be achieved by Huawei Mate 10.
Last but not least, if the USB PD fast charging protocol is supported, it does not mean that USB PD fast charge can be achieved. When you need to buy a USB PD charger, the relevant parameters of the charger should be first understood.
https://www.ugreen.com/news/186-en.html
If Huawei supports more USB-C PD profiles (which very few chargers do) I don't want it to be at the expense of their faster Supercharge technology, which delivers 22.5W of charging power making it one of the fastest charging cellphones ever. In my use when I'm on the go in overseas trips, it's really invaluable and I can't do without it.
http://consumer.huawei.com/en/phones/mate9/power/
There's improvements though on the horizon. The latest firmware of the P10 already tested by some people to support USB-C PD Profile 2, which is 18W, Profile 2: 18 W (5 V @ 2 A -> 12 V @ 1.5A). If you read the testing carefully, it requests 9V 2A but the Google charger gives 9V 0.9A - which may signify a protocol issue but in near future the PD spec will probably be implemented better both by device and charger manufacturers.
https://gtrusted.com/the-huawei-p10...works-with-the-google-18w-pixel-phone-charger
Until then, the Huawei supercharger works great, and (relatively) cheaply available from Huawei service center for extra units, so I'm happy with that.
donetus
has anyone tried the moving picture? how do i send it to another Huawei user so that they can also see it as a moving picture?
Ruriel
how much overnight battery drain are you guys experiencing?
Is it weird that my Mate 10 doesn't drain overnight no matter on WiFi or mobile data? I plug off the charger at 11pm, and did not touch the phone until 6am. It usually remains at 100% when I wake up in the morning. Sometimes at 99% or 98% if someone msged me late at night after I slept and the led notification light blinked throughout the whole night.
knave
Cos all phones usually overcharge, likely due to battery calibration. If you notice your devices all stay at 100% longer before it starts dropping fast.
This applies to Apple devices and laptops too.
Bumblebee Man
Any recommendations for screen protector? I got 1 from ah Beng shop but it's a little small, leaving too much gap not covered.
Sent from HUAWEI BLA-L29 using GAGT
