Huawei Mate 10
watzup_ken
Yeah lo, even though it only stated "security patch", but seem to improve the memory management.
Before that after 1 week never restart, it will take 3 seconds to open my camera app lol, until I restart the phone to reset the memory. Now 1 week liao still ok.
I think the problem is that they are not 100% transparent about what they are fixing. My last update to 139 came in a massive 1.39GB download which sounds a little too much to patch some security issue.
watzup_ken
https://9to5google.com/2018/07/25/vlc-media-player-huawei-devices/amp/
Hmm... I don't know why Huawei kill app so aggressively. Not sure about VLC but I notice Plex app also can't play video properly.
Battery life is the main issue. Android is definitely too open source and far too often we seen sneaky app makers allowing their apps to continue running very aggressively in the background. Apps like Facebook is a good example and you can really save quite a fair chunk of battery and resources without installing it.
I feel they are trying to take a page from Apple's iOS where it can get pretty aggressive in killing apps, although Huawei seem to have overdone it.
OutBreak
Indeed. EMUI also keeps killing Blokada. I need to start and stop and restart the app every time. It pissed me off so much that I stop using that app. It feels worst than getting full screen ads in your face..
Another aggressive app that keeps refreshing in the background is Carouhell. It gets more and more bloated every update.. :D
deathst
Not true, look at Pixel line. They have smaller batteries and their devices last so much longer than phones with batteries close to double their size. It is also a lot dependant on Manufacturer optimization. Killing off apps in the background is actually very very un-needed and actually can hurt your battery more.
You are just messing with Android's system in prioritizing applications to keep alive and within memory. In fact, you want to keep them in memory so you do not have to waste and burn CPU cycles reloading everything from disk and since you force closed them Android itself might restart it back due to it's required services and your effort is wasted and it is worst now that you don't even see it in multitasking tray. Android is smart enough to handle all of this already, messing with stock settings is not the right way.
Apple in-fact does not kill an app in the background instead, their apps come to a complete stop less the services it may run for notifications. (I write apps for iOS and Android both OS does the same now) What is more impressive that it even compresses the resident memory of the app down to as low as 10MB from apps that can take up to 300-400mb when active. Then only time they kill apps is when the system really needs it but it is rare it does thanks to the compression (Some Android does not have)
The only time to force close apps when they're unresponsive.
titank
Dear All,
I need help on my Huawei Mate 10. When I tap the mobile data network to go this website http://dramacity.io/ it show WEBSITE BLOCKED. The site you have requested is Blocked because of Teens setting.
When I use my Home Broadband I do not have this issue.
Anyone could advise how to overcome?
haylui
Dear All,
Contact your telco for further details?
Audiology93
Contacted my Telco M1 but they said I did not do any restriction. Even this website I click also show the same block message.
www.sgcarmart.com/carpark‎
Maybe those have Mate 10 could try see is it have the same problem like me.
No issue on my Mate 10.
Sent from HUAWEI MATE 10 using GAGT
|XcElLeNcE|
Dear All,
Check with M1 on whether do you have Cyber Guardian VAS activated for your mobile number.
SevenSeals
Im on 139 since prompted for update, noticed the batt life got better. now can run for ard 2.5 days compared to 138, which only lasted 1.5 days on avg.. usage pattern has been same through out
using m10pro
Sorry but how did uou get firmware 139?im still on 136 on my Mate 10
OutBreak
brawl Stars, but in the 4 hours SOT i get, less than half an hour of those are from the game..
Just Google it. Brawl Stars has high battery drain not only for mate 10. Probably the game is unoptimised..
TheOutsider
Mate 10 and Mate 10 Pro version number different. Mate 10 Pro number slightly higher. The next update for Mate 10 is 138. Still waiting for it to be approved for our Mate 10.
That will include the night shot :D :D
Next one will be EMUI 8.1 with GPU Turbo and the AIS camera. Don't know when can get that. Looking forward to it.
charleslin
Outside China it will be GPU Turbo first.
EMUI 8.1 will be after that.
progene
Night mode is here for mate 10.
And mate 10 Pro
Sent from HUAWEI ALP-L29 using GAGT
