Huawei Mate 10
eden1988
Can actually order the 6GB 128GB storage Mat 10 non-pro from Aliexpress for US$469.59.
https://www.aliexpress.com/item/Glo...&terminal_id=8ec6d9fbf2d94b8c8f4254f84c9b076c
Is it advisable or there too many negatives to buying online from overseas?
Kasia mobile selling brand new M10 for only $500.
http://kasiamobile.com/huawei/
Shib
Anyone seen the 960 slow motion recording? Suppose to be one of the upgrades
Sent from HUAWEI MATE 10 using GAGT
TheOutsider
Seriously don't be bothered by the 960fps. Huawei phones all don't have the needed hardware to achieve that. All by software up from 240fps I guess. You can google for P20 Pro slowmo comparison then you'll know.
Can't say for sure on Mate 20 and Pro though. Have faith :D :D
TheOutsider
Thanks. Looks like if need raw computing power, better stick to the SD ones.
Not raw computing problem but rather the camera sensor itself. To implement 960fps, the camera sensor has to support it and also must have the chipset to buffer for that short burst of slowmo video.
From the buffer then the data unload onto the phone SoC and saved in phone memory. It's known that the sensor in Huawei P20 Pro don't have the buffer memory to achieve that and that's the reason why it can't do it.
Shib
Thanks for sharing.
chenaz
First the hardware must support. Second is the software trick.
If the hardware cannot support. Your software still cannot make up the difference
Not real 960fps. Just like GPU turbo..all software tricks.
guruking
I always receive goggle play ads thru notification. Any way to disable this irritating ads on the M10P?
