What kind of ads ? I didn't receive any ads before ....
Is app ads. For example, I rec'd map app similar to Google map.
Hmm I never encounter such notification, show a screenshot of it?Is app ads. For example, I rec'd map app similar to Google map.
Yes.. still under EMUI 8.0.0For Mate 10 it's still under EMUI 8?
Sent from HUAWEI ALP-L29 using GAGT
First the hardware must support. Second is the software trick.
If the hardware cannot support. Your software still cannot make up the difference
Hopefully pie is coming soonWow b145 update is out with October security patch. That's fast. Usually have to wait till following month
Thanks broHmm I never encounter such notification, show a screenshot of it?
Anyone managed to compare the photo image quality with mate 10 and mate 20?
Sent from HUAWEI MATE 10 using GAGT
Great! Wait for your next post.Just gotten my M20
Will post some shots on M10 to compare later. Totally worth the upgrade �
Posted from PCWX using HMA-L29
It's still beta, based on the articleHuawei P20/P20 Pro, Mate RS, Mate 10/Pro and more to get EMUI 9.0 on November 10
https://www.gizmochina.com/2018/11/...-pro-and-more-to-get-emui-9-0-on-november-10/
Whaaaa... Another reason to stick with Mate 10 for at least a yr.It's still beta, based on the article
Hopefully the official release will come soon
