Huawei Mate 10
taeception
Bought my mate 10 yesterday, and currently I am facing some issues. I inserted a new sandisk sd card, with the intention of wanting to transfer my files (music, pictures) from my old sd card to this sd card. However when I tried to do that (Transfer stuffs from old to the new sd card in my mate10), i cant seem to do it. There is an error sound however there is no error window or smth..
sunht
a bit difficult to understand your issue, are you saying you want to copy from old SD card to new SD card in the phone? Don't think the phone supports two SD card at the same time. You can do the transfer on computer
deckcard
The error is from the new card? Where did you copy the data from? You copied to phone internal storage then want to copy to new sdcard? What app you used to copy? Did you format the new card using the phone format function?
HuatKway
yea this. try to format and re-mount. i had issues with mate 9 initially. but after that ok.
harky
becareful when u use oil.. my bro use it on his xiaomi 4x, and the oil went into the LCD - cannot repair because is user problem.
i think he used too much.
nw the LCD got oil marks.
Got my case and screen protector from taobao and was surprised to find the oil for fixing the white sides supplied. End up have to use cos the side
are slightly curved.
iamnagel
My experience is sooner or later sure will have white gap again. Have to look for slightly smaller TP again.
superio
Hi bros,
Where can I get to hands-on a working set of Mate 10 Pro?
Anyone knows if there are units available for us to take a look at the following places?
- Plaza Singapura
- Vivocity
- Suntec
- Ion Orchard?
Thank you!
knave
Hi bros,
- Plaza Singapura
- Vivocity
- Suntec
- Ion Orchard?
Thank you!
Best denki @ taka, Huawei shop @ 313
