Huawei Mate 20
Geros_Peters
I'm using the UAG Plasma case. Suitable for my usage and also I like the design of the UAG case. Photo of my M20Pro in UAG Plasma Case.
Anyone tried Plasma and Monarch UAG case? Worth the $20 diff?
Sent from HUAWEI LYA-L29 using GAGT
Lobaba
The given one like quite soft along the screen. Lol doesn't feel solid. Will try out.
Yea it is, when it was gripped by the car mount phone holder, my screen actually got 'touched' by the grips so end up when I try to zoom in on google maps, it zoomed out.
Ordered Cafele ultra thin casing and spigen casing...waiting for their arrival..
ahtionginsg
Anyone tried before rwm glass and wwp one? Which one better overall?
i tried WWP. fingerprint sensor obviously is affected despite all promises. however still a good job overall so now i disabled fingerprint and use facial to unlock.
not sure about RWM.
athenodorus
not sure about RWM.
My RWM one also affecting my fp scanner. And it has a scuff so I’m going to try the wwp one and see if it’s any difference. It’s much more ex and not loca type. They claimed won’t affect fp but I’m skeptical about it. The packaging also looked like some tiong generic ones.
Last resort is just use film next time.
ahtionginsg
i dont recommend WWP, unless you plan not to use fp. but even so, the black border is an eyesore as well. for me, i would just put a cheaper film one until there is more promising solution available.
athenodorus
The side borders can be an eyesore ya esp when using with the default case. Hais. Somehow the fp works much better than my RWM leh. I still find it ex for a generic non Loca glass.
I'll use it till I change s10 ba.
savior1
Anyway got follow up from Huawei yet regarding their message on Facebook about the screw up at the CWP launch event and compensation? I got message to leave details but nothing yet...
athenodorus
The black borders also annoying when I'm playing landscape games sia..ahhh.. suck thumb.
Exia14
Anyone tried Huawei m20p silicon case? Any review compare to the free case given?
Bought the black one, the coating that made it smooth at first touch is frustrating. Slip out of hand frequently, but causes friction against fabric when placing it in fabric (skinny jeans).
After a week, there's visible difference of coating at different contact points of the case. Conclusion, stay away and save that $28 for something else. Of course disappointed at how it compares to Apple's silicone cases but between $28 and $59, its a comparison of apple to oranges.
maur_james
not sure about RWM.
I suffer the same fate as you, not as lucky as some of them here.
s-ghost
High Honorary Member
finally had time to set up my new mate 20 proper :D:D
just some questions:
- warranty don't need register right? just base on the receipt date?
- possible to tap and wake up the screen up?
- you know when you group apps into one folder, then when you tap into the folder, it only shows 3x3 apps at one go, possible to make it show more?
- any fun features to explore and make use of from this wonderful phone? i tend to duplicate my own phone and continue using it as per normal, want to make full use of it :s13::s13:
James Tang
Managed to get a 256GB NM card from AliExpress
[/url]IMG_20181113_154814 by TangKF, on Flickr[/IMG]
IMG_20181113_155000 by TangKF, on Flickr
Seller is very responsible as he actually sent me a PM on how to cut the packaging of the NM card without damaging it. Apparently there have been cases when the card is destroyed.
wjx1996
Are you guys able to read the huawei nm card on your PCs using the huawei 2 in 1 card reader?
