Huawei Mate 20
Searingmage
Saw tb got protector for the camera glass.. But not sure this will affect the photo taking ma? Cuz I know we not supposed to take pic through glass right? Sry if noob qn
Sent from Samsung SM-G955F using GAGT
I don't think taking photo through glass will have any issues. The lens is also going through glass now..
The bigger question is whether do we even need it.
I know iPhone used to state that their glass is sapphire crystal. So unless you're really careless, it likely won't scratch/break. In this case, then a TP will not be necessary.. And my s7e is likely sapphire crystal as well (I recalled reading something few years back but not sure if my memory failed me), and I don't hv any scratches after using for 2.5 years (camera glass only)
But if HW is using gorilla glass etc, I think we may need it, as it will scratch quite easily..
siaoz85
Anyone knows what changes comes with this software update for mate 20 pro?
Searingmage
Thank you I will try. For the UV/loca type of sp, I'm wondering if in future wanna replace, can it be easily removed?
Sent from HUAWEI LYA-L29 using GAGT
Based on my understanding (as well as vendor's comment), should be take out like normal tempered glass.
Geros_Peters
I ordered tempered glass for my camera lens via ebay. Will post my reviews after it arrives.
deadrick
mate 20 pro is quite heavy sia.. use until pinkie pain when the phone rest on the pinkie while using.
+ spigen case not much grip, abit smooth and slippery.
MisterU's
You will get 2 updates one is around 5+ mb and another with 100+ mb. Which comes with 5 games
:) that's funny, an impt system update followed by a 100mb that contains games. Thanks for the info.
mafia86
Hi, for those recontract with Singtel, the Huawei Mate 20 Pro Redemption voucher is inside the box with the phone or is a separate paper / card?
xcrawler
If u are referring to the wireless charger redemption, it come separately. Not inside the box
Geros_Peters
I'm on my 3rd pc tempered glass with uv glue, saw them remove twice, wuite easy to remove. No issues.
jackycar
Everytime I try to save mnew contacts.. It defaults to saving the contact in phone memory.
Anyway to make it default to save the contact in my Google account?
