Huawei Mate 20
zacky1223
sorry guys can I check how do I disable the message being shown when the notification show up ? I just want to show the name of the person send to me and just a "whatsapp" notification.
aallzz
I've got my device changed on Tuesday and guess what. TADAHHH!!!! don't know to cry or laugh. Maybe should go buy 4D
Terrible bro. I also exchanged on Tuesday. Is it LG or BOE? And which color?
athenodorus
Next time just insist to them u want BOE screen ba. Don't waste time take risk with LG again.
pandaammonium
Hey! Those of you who have gotten a replacement, care to share what the middle alphabets/digits of your serial number are?
I read on xda that you can tell if it is new batch without opening box/installing Device info hw app.
The serial S/N is in this pattern XXXXX18A23XXXXXX
18 = Year
A = Oct batch, B = Nov batch
23 = day of the month..
Those UK users in xda saying they are receiving the “B” batch and are more satisfied... but also got one guy got B batch LG screen same green problem... so.... :s11:
Aikon
18 = Year
They are probably still using both manufacturers, so really it's your luck.
flyingeagles
18 = Year
thanks, this should at least helps to serve as a first checking step at the point of exchange.
leon0079
This is mine. Exchanged boe set. Looks accurate
Sent from Huawei Mate 20 Pro using GAGT
jlekssp
Instead of A or B, mine is a digit! Is that right??
18 = Year
aallzz
I bought the tgsp at Red White mobile.. Any recommendation for cases in which the tgsp will not pop out? Other than UAG..
Abyssal.Xuan
If you want a clear case can try the otterbox symmetry from casefactory $49 though.
Not sure if can fit the tgsp cos the case just release I think
