Huawei Mate 20
plustwo
does anyone have the problem of background apps getting killed even though you turn off auto battery management? some apps push notifs are not getting through even though i allowed background processes. also, i cant control chrome's settings so that's particularly annoying.
bystander1965
Ya. My clock widget kept stopping even with battery setting like you did.
So I have to disallow battery optimisation for that completely.
App/app/setting(the 3 dots on top right) /special access /battery optimisation and set not allowed for my widget.
athenodorus
U can try disable battery optimization under apps setting.
drmlxx
hi guys, planning to get my screen protector from red white mobile tmr. anyone can send a pic of what the tempered glass looks like on mate 20 pro? any problems with fingerprint or face unlock? thank you
sajokj
No issues with FP and face unlock. Happy with it
charleslin
anyone noticed a slight yellowish tint on their Mate 20 LCD bottom edge?
Not sure if it’s related, but my Mate 10 LCD also slight yellow at the nav bar since day 1, slight only though so never really bothered.
plustwo
you can order the same item from ebay for $2 if you are willing to wait for a week
hello123
Phone heat up and turn green
My wife was disappointed with this phone. Screen get heat up and turn green
knightcover
Told you guys liao, buy mate 20 non pro, no such issues. Gey Kiang.
Sent from Your Mama using GAGT
