Huawei Mate 20
liuhao
Can bro. See your Hicare app on your phone. Click on spare parts price.
checked and the price for replacing battery is $30 (labor) + $19 (new battery).
maybe can do that 2 years later if battery capacity worn out.
wrathbringer27
This is probably what RWM was previously using;
Full Glue Tempered Glass Film for Huawei Mate 20 Pro Full Screen Coverage 3D Liquid UV Screen Protector Glass
https://s.click.aliexpress.com/e/cNgyWc75
This is probably what they replaced it with;
So RWM no more selling the old one? Any more nice glass protector to recommend?
RestInPepperoni
They said they might not be getting the old one anymore, but if a lot of people ask for it, they might bring it back, so call them or go down and ask them for the old one!
Also, the old one was the perfect size and fits perfectly. The new one has a lot of issues, looks ugly and essentially renders the curve side of ur phone useless coz it stops mid-curve.
How many pieces of the small one did they exchange for your case?
They only willing to exchange 1 for 1 :/
u pasted the same link bro
bellick
Both links are the same but when you select options, there's full coverage and case friendly. They probably replaced the full coverage with case friendly version
drmlxx
oh crap... was gonna get my m20p tempered glass today, but the old one seems better than the new. should i get the new one or wait for the full coverage one?
drmlxx
IMPORTANT PSA! FOR THOSE BUYING FROM RedWhite Mobile Screen Protector:
I just checked with them yesterday, they CHANGED the screen protector they are using now. It's now a china brand one, and it's much smaller, so it doesnt cover a lot of ur curved side class as well as top and bottom. When u have the screen protector on, because it is not curved fully, ur screen at the side extends past the screen protector and the screen protector looks like it is sticking out. This basically means it looks super ugly and the whole side screen cannot use. Might as well buy another phone with large side bezels. If ure thinking about buying it, just beware of this change, and help let them know to change back to the old type.
Also the screen isnt smooth now, if u look at reflections of a straight object, u can see it has curves and distortions. And they dont allow refunds, they only offer "exchanges" or paste new for you but dont want to refund you, so once you pay ure fked.
Might just be backlight bleed, happens on a lot of LCD screens, maybe ask to exchange it also
phew, thanks for the warning... was gonna spend my $30 for nothing later... ill just wait for the old protector to come back.... using the phone naked now with just case abit scary
xiaosen
Ohh confirm they using this? Feel like ordering but seem like no review.
kirium76
This is the rwm glass that was applied yesterday. It does cover the viewable display when looked from the front. This smaller sized glass is able to fit the free case. For the distortion lines, they should be able to see it on the tempered glass before the application and change to another one with no distortion lines.
Sent from HUAWEI LYA-L29 using GAGT
drmlxx
This is the rwm glass that was applied yesterday. It does cover the viewable display when looked from the front. This smaller sized glass is able to fit the free case. For the distortion lines, they should be able to see it on the tempered glass before the application.
oh i see, so any distortion on screen protector when on the phone? any issues of fingerprint/face unlock? any significant diff between old and new glass other than the size/case friendly?
kirium76
For mine is OK. No distortion lines under reflection light. But best to check the glass first before application. I never pasted the previous version so won't be able to comment the differences. To be safe, maybe can wait for the old version bah. Maybe those who are using the bigger version can share their photos on the coverage area for reference?
rapcon
anybody tried out the HiAssistant? The Google Assistant doesnt have English (Singapore).
kirium76
Anyway to have some gesture to pull down the notification panel? I swipe down the home screen and only triggered the hi search. :(
Sent from Samsung SM-N950F using GAGT
1982-1994
Settings > search for system Navi > three key navigation > settings
drmlxx
your tempered glass seems okay. especially now my case already covers the sides of the phone so im ok with the half curve of the glass.
JayBeeLwashere
Is the default volume slider is media when you press the volume key for everyone else? How to change to change ringtone volume by default or i have to keep pressing between vibrate/silence modes to enable the double volume view?
GReddy G9 RS
I have this issue on my mate 20 too, did post before but no answer. So just live with it.
Sent from HUAWEI MATE 20 using GAGT
bellick
I believe in android pie 9.0, Google has changed it such that volume keys will by default change media volume only.
GReddy G9 RS
I still prefer the default is ringtone n when watching video or youtube it's auto change to media.
