Huawei Mate 20
tomzhang100
send to service before 2 years expiry. normally the battery capacity is significantly dropped. they will update FOC
checked and the price for replacing battery is $30 (labor) + $19 (new battery).
maybe can do that 2 years later if battery capacity worn out.
flyingeagles
Anyway to have some gesture to pull down the notification panel? I swipe down the home screen and only triggered the hi search. :(
Sent from Samsung SM-N950F using GAGT
I am using j touch, recommended by some user on HWZ previously. Can also customise your own settings. Highly recommended.
Sent from HUAWEI LYA-L29 using GAGT
wrathbringer27
Yes sorry. Its 2 different ones you can choose from that same link zzz my bad
They said they might not be getting the old one anymore, but if a lot of people ask for it, they might bring it back, so call them or go down and ask them for the old one!
Also, the old one was the perfect size and fits perfectly. The new one has a lot of issues, looks ugly and essentially renders the curve side of ur phone useless coz it stops mid-curve.
They only willing to exchange 1 for 1 :/
u pasted the same link bro
wrathbringer27
For those who wants photos for the original or older version of the RWM Tgsp.
Sorry, I dropped my phone hence the crack and chip
Lmk if you need more photos
AcEz874
Hi guys, I have jus renew my contact with singtel and obtained Huawei p20 pro with wireless charger redemption letter. Anybody know on top of the orginal singtel invoice, if is my ID still required to redeem the wireless charger from 313 Somerset
Redemption details says you need to provide the original form duly completed and signed by customer and need to present original ID or passport, original proof of purchase documents and including printed invoice with receipt.
AcEz874
Will the not full version able to fit Spigen Rugged case? i'm using Spigen Rugged case at the moment and also bought a UAG Monarch.
drmlxx
looks similar to what i had before. but last time, mine is dot matrix and the glue only at the sides only, so once it pop up then cant put back alr... wasted my $15. am using a similar case to yours right now, thinking about whether i should make the trip down for the new one or wait for the old one.
wrathbringer27
It's personal taste, really. Do you want more flexibility with different cases at the expense of lesser coverage or vice versa. But for the money, you get more glass lol
yang_nastyman
Anyone has recommendation for mate 20 nonpro screen protector that covers the entire bezel?
I recently replaced to tempered glass but the darkened borders has created a bezel that is covering my screen.
athenodorus
Anyone tried the tempered glass from sls gwmobile?
Is it good?
I tried before. Their work station so messy and dirty. The person who did my phone tried a few glasses but kept having some dust inside. I also realised because of the multiple installations there’s glue slipped onto my earpiece receiver. The guy insisted it was not done by him. Zzz. Lucky I managed to remove the dried glue on my own without damaging my phone.
Never gonna go to them neither will I ever recommend them at all.
kirium76
My experience there was not too good either. The tempered glass was hardly cured, at most 15 to 20 secs and passed the phone back to me. And the glue was still leaking at the sides and kena the buttons. Have to wipe continuously to remove the glue in case they got stuck with the buttons. The guy said it's normal for glue to leak wor. But I insisted for him to cure longer so that it won't continue to leak. He did in the end, but somehow reluctant. But he did use some sticker to cover the earpiece for my case :(
athenodorus
The way they handle the phones is unhygienic and messy. The guy (I believe is the boss) told me he can't control if there's dust below the glass. I was like duh of cos u can, it's because their work station is so messy and dirty. Sure he did use sticker to cover the receiver but that doesn't mean glue can't sip through the sticker. If the glue can sip through wouldn't it mean there's a lot of glue overflowing? It shouldn't be like that.
When he returned the phone to me its like so oily everywhere and I had to tell him to kindly clean up zzz.
Comparing the service standard between gwmobile and rwm is heaven and earth.
