Huawei Mate 20
cheery
Anyone's Mate20 when off, auto on itself when charging cable is plugged in from powerbank?
petricnah
Saw this on AE, just sharing.
High-tech Ultra-thin UV Glue Tempered Glass For Huawei Mate 20 Pro Bend Edge Cover Phone Screen Protector Transparent Film
https://s.click.aliexpress.com/e/btNFptKu
Dolcefarniente
anyone seems to noticed theres an eye icon appearing on the notch. recently i saw it on my lock screen notch. yesterday was on the left, today was on the right
newuserid
eye icon = eye comfort = blue tint for night reading
you can turn it on in the settings, or pull down from the top (extended menu)
Gondon72
finally found that 水凝膜 can be use with Spigen casing. now buying another TP glass one from taobao to see whether suitable or not.
kirium76
This is the film type right? Good to use with full coverage inlcudjng the notch? Can see Pic?
Sent from HUAWEI LYA-L29 using GAGT
keith00
It is those need to apply with water?
Spigen had those but only available in US
cheery
Yes i also have that. didnt try with cable charging but wireless it turns on autimatically
Thanks.
I also noticed a problem with Toggle app. If screen off or go other apps.... wanna return to the Toggle app for control .. the app freezes and asked to close app.
Anyone have same experience too? Already sent bug reports to Toggle.
savior1
Hi, anyone got issue with force close apps? U know when u press the square icon then it shows all the apps open the u press the trash can icon to delete all apps? Funny for me sometimes I close all then it says your phone is in optimal condition but when I bring up the screen again some apps still open like facebook, wunderlist.
Anyone else?
Warren28
Anyone else?
Is there a padlock icon on the leftover open app? You may have swiped dwn telling system not to force close the app in the background when hitting the trash icon
plustwo
i am very upset with the phone not letting my apps run in background even though i disabled battery optimisation. help!!!
