Member2020
- Nov 20, 2018
i am very upset with the phone not letting my apps run in background even though i disabled battery optimisation. help!!!
What are those apps...?
Is there a padlock icon on the leftover open app? You may have swiped dwn telling system not to force close the app in the background when hitting the trash icon
messaging apps like telegram/whatsapp/twitter, system apps that don't show up in the list like chrome and other apps that need to send push notificationsWhat are those apps...?
basically everything
Swiping down the app from the recent app list will toggle lock on and offamazing thanks! fixed my issue![]()
btw how do i attach a lock on the app? Now I want to see some apps dont force close...
both under battery > app launch right? i enabled all 3 for the apps i need running but no difference. i don't want the lock to keep the app running in the background, i just need the push notifications background service to keep running instead of getting killed by the stupid emui battery optimisation rubbishThere are two settings, one is manual launching of apps and another is battery optimization. You can also lock the app in the recent app list to avoid accidentally closing on your end
I'm sure it wasn't a software bug. How did it suddenly go? Did you try a dark room scenario?
Yes. I did tried to toggle the brightness to verfied the issue. I also use the device info LCD testing to double check.
At first I tot is I apply the water screen protector that
Covered the green tinted . So I remove the screen protector and still can't see the green tinted issue.
This is my original issue. Now cannot see at all
notifications are allowed but they only come in as a tsunami if i open the app, meaning the background notification monitoring process is getting killedSaw your earlier post a few days ago.
Actually I am not sure what your question is.
If you are saying you don't get notifications of new messages, then it's not the background process issue, and hence battery op setting will not do much.
If it's notification, have you checked the individual app's notification setting? Is it set to "allowed"?
It should be just some setting and not the phone problem as the notifications work for others, me included, and the list of apps you put there are common apps.
nova. dont think launcher should affect anything?What launcher are you using?
Anyway congrats
Maybe software wise they do not allow certain color to be displayed and help lessen the issue.
Normal usage no diff? Still accurate colors?
It does if u are using teslaunread and u are referring to the unread counts not showing up.nova. dont think launcher should affect anything?
If this is the case then u must give permissions to teslaunread.
For notifications on top each and every single one of the apps must be allowed to show.
I used phone clone to transfer everything from my old phones and I found out all apps didn't the notification allowed by default. I had to go to each app and turned it on.
I tried nova and tesla unread, super buggy with the unread badges.. That's why switched back to emui and the unread badges work perfect
