Huawei Mate 20
ieast
Any one knows how to make Google photo editor the default editor in Huawei Camera Gallery?
deckcard
You cannot specify editor per se but you can specify default galley to Google photo. Just go to setting page and search for default app
lorettatay
Starhub here still nothing
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
Danxviii
Hello, does toggling with the "App Launch" settings help to save battery? Not too sure what this settings is about, can anyone advise? Thanks!
Add on: Does turning off "manage automatically" prevents the app from getting killed and thus, enables push notification? Like on iOS my ML game normally have push notifications, but on huawei I don't receive it
Member2020
The Mate 20 & Mate 20 Pro Review: Kirin 980 Powering Two Contrasting Devices>
https://www.anandtech.com/show/13503/the-mate-20-mate-20-pro-review/7
p0mp0m
Mate 20 pro tempered sp, which one is the best now ah? In terms of good fingerprint scanner, can fit most cases and maximum coverage of the screen?
Anyone tried hydrogel?
I follow this thread everyday since it started, but cannot remember which post has the recommendation haha.
1982-1994
Yes it does help. Whenever I install new apps, I will toggle it back on and off again.
keith00
Don't try hydrogel.
I tried.. Cant paste properly on the curve..
Would recommend the neo flex by spigen.. Tried on my S8+ really good and pasted well.. But not tempered.
Not sure if available for mate 20 pro
kirium76
Don't try hydrogel.
Spigen neo flex is a wet application and the finish somewhat got those orange peel effect under reflected light although it does not affect the screen clarity. I understand some tpu film doesnt require water application and has installation kit to aid the pasting. Saw in tb before and some has positive reviews.
Sent from HUAWEI LYA-L29 using GAGT
keith00
What kind of installation kit? Can share pls
Usually they just install the wipe and sticker dust remover which don't really help the pasting.
Especially with the cruve which easier pop up
I also prefer tpu film then tgsp
kirium76
It's just to aid the positioning of the film. To be plugged into the charging port.
