Huawei Mate 20
Audiology93
Anyone problems with downloading Google Pay? When I want to download it in App store, it says that the phone is incompatible. Strange, on my Mate 9 it worked flawless..
No issue on mine. Able to install it.
Sent from HUAWEI Mate 20 using GAGT
bystander1965
Is this for sure? I got the reader hoping I can transfer files from PC to the NM card without linking the phone.
It works for me.
Firstly make sure you put it in the right way. There is outline on the reader.
Secondly make sure you push the card all the way in. I have to use my nail to push the last 1mm in. Use the release latch as a guide. When you insert the card, it will start to move inwards. You must push the card all the way in such that the latch completely moves to the other end.
striker22
Thanks. Good to know it works. I will be sure to do what you say once I get the reader from China
It works for me.
Skyy
currently using oneplus 6t, tempted to try the mate 20 pro. But the gesture navigation on emui like quite sucky. Anyone using gestures?
what i miss on the mate 20 vs oneplus phones is the double tap to wake. that's the best feature man..:s13:
s-ghost
High Honorary Member
why i plug in mate 20 it doesn't auto supercharge, instead it only shows charging?
petricnah
Does anybody's NM card reader work? I can get the microsd to work, but not the NM card. It isn't recognized in my PC and phone
Any ideas? Could it be that the phone encrypts the NM card?
Sent from HUAWEI HMA-L29 using GAGT
My not working since day one(launched day). Was told by CS(Facebook) to do an exchange @ 313 but no stock. They said they will call me, but..... Till not, no news from them.
maur_james
I noticed that after the recent update, my wireless charging gets abit cranky at times. Sometimes it will charge for a while then does not carry on charging, until the phone is re-positioned then it will start charging again.
s-ghost
so it's an update issue? for mine is it doesn't supercharge
CHOCOx33
Hello all! Have been following this thread, but forgot which shop have the most suitable screen protector haha.
I just hooted a clear Spigen case for Mate 20 Pro, but the current screen protector is getting on the way! Intending to change the protector soon, more probably tomorrow. Can anyone recommend me the suitable one (preferably without any border line, those black border type)
The Spigen case in question is this: https://www.spigen.com.sg/st/hw/m20p/lc.html
Many thanks! Loving the phone so far, no LCD issue cos my phone is from the 3rd batch, which I suppose that Huawei have fixed it.
striker22
I think some people like to double tap to wake because they put the phone on the desk or don’t want to lift up the phone to see notifications.
kirium76
Which glass r u using now? I'm using the liquid crystal case too.
Sent from HUAWEI LYA-L29 using GAGT
CHOCOx33
I am using the one Huawei Customer Service Center (at 313) is selling. TBH, it sucks cos the salesperson claimed that the protector can fit into the free transparent case but it is not the case.
If you try to take off the case, it will also cause the corner of the protector to peel off too. Kena this at 3 of the corners ): need to replace it soon, after getting the Spigen case which I have ordered like 2 days ago.
P/S: after checking my initial post here, it sounded as if I am using the Spigen case now. Sorry I meant to say that I ordered the case 2 days ago and is now waiting for it to arrive. Meanwhile, I am using the free case at the moment. Haha, me and my sotong brain.
