Huawei Mate 20
Audiology93
yes original, i plug in and left it there, normal charging throughout till 100%
That's weird. It should be able to super charge if you're using the original charger and cable.
Is there any way to see the amount of free/available ram? Used to be able to see it on my Mate 10.
Sent from HUAWEI Mate 20 using GAGT
I realized after update to latest firmware my battery not that good
Sent from HUAWEI Mate 20 Pro Emerald Green using GAGT
Normally I don't update except for xiaomi phones,which have not much to zero impact on battery life.
Jun Kid328
When I look at my Phone (Huawei Mate 20 Pro) from the side it looks like there's a slight tint of green from the display but looking at it head on it seems normal. Does anyone else have the same problem? This is my replaced mate 20 Pro due to green screen and it has this problem.
RestInPepperoni
Add a widget to ur homescreen, it's under settings shortcut --> Memory
Audiology93
Are there any other ways other than having to go into the settings app? It was much more convenient if I could just press the multi tasking button and it show the amount of ram right above the bin.
chenaz
Normal. I just got my replaced set and the whole screen is greenris but from front then is normal and bright
RestInPepperoni
Not any that I know of, but tbh you wont ever need to look at your ram, 6gb is more than enough, and it doesnt really matter, mate 20 is known to have some pretty aggressive ram management too
Strange .their official website didn't say have super charge . mate20pro version they did indicate got super charge.
Before their official release also say no super charge. Because of this super charge thingy I buy the product version .
Tmd
To clear this up, only mate 20 PRO has super charge, while the others only have fast charge. The difference is Pro uses 40W charger, while normal uses 22.5W. I think the one u see is their "fast charging"
