lorettatay
- Feb 10, 2001
Yup thicker and safer to useis it thick? compared to the original from HW?
Sent from HUAWEI Mate20 X using GAGT
To clear this up, only mate 20 PRO has super charge, while the others only have fast charge. The difference is Pro uses 40W charger, while normal uses 22.5W. I think the one u see is their "fast charging"
But u all allot of them replied my post and said they are using mate 20 and they have seen the super charge . And confirmed that mate 20 has it.
That's why I felt strange. I remembered I bought mate 20 pro because if this and now our mate's here says mate 20 also has it
Seriously man, do you really think charging at such high currency using 40w is good for your battery? I know many ppl think it's OK. But the wear and tear sure higher just considering the higher temperature. Mine is m20pro but I don't use 40w super charge. I dont have to either. There is no situation that in such a hurry. 20w is fast enough for me.
Sent from HUAWEI LYA-L29 using GAGT
Car A can go from 0 to 100 in 3.5s
Car B 14s.
Does it mean car A will fail first, all else being equal?
Good example and yes indeed, practically, car A will fail first.
Not any that I know of, but tbh you wont ever need to look at your ram, 6gb is more than enough, and it doesnt really matter, mate 20 is known to have some pretty aggressive ram management too
but no one reply me why my mate 20 suddenly don't do supercharge anymore
anyone facing the same problem?
my cable failed before and won't supercharge, luckily a fer HW in my house and other cables works.
but my one is new set fresh from the box, less than two months only
2 mths isn't fresh from the box.. Probably someone sat on it or bent it and there was breakage inside
not really also...weird sometimes have sometimes don't also
what's weird is that you have henry thia cosplaying an avatar as your avatar![]()
Supercharge is 5V 4.5A for 22.5W and 10V 4A for 40WNot any that I know of, but tbh you wont ever need to look at your ram, 6gb is more than enough, and it doesnt really matter, mate 20 is known to have some pretty aggressive ram management too
If you mean the screen turns on, then If you turned on Developer mode, there is a setting that says "Stay awake on charging", or do u mean the phone turns on when u plug it in? That is normal and I dont think there's a way to change thatWhen i off my mate 20 n put it to charge the phone auto turn on itself. Is it possible to disable it?
Sent from HUAWEI MATE 20 using GAGT
