Huawei Mate 20
RestInPepperoni
However, finger print does work on mine. but better let them know. I also noticr that the tgsp is not applied accurately: one side has more space than other sidr and is quite obvious.
best to get tgsp elsewhere e. g. Red white mobile
Nah, red white mobile not good anymore, they changed to a smaller one that only covers the flat part of ur phone, curve part a bit only, basically ur side cannot use liao and quite ugly coz it covers partially, plus the new one quality not good, the glass not smooth, if u see the reflection. Then they dont even allow refunds, only say they change a new one but also got same issues. Im guessing they want to cut costs coz a lot of us here recommended them last time and we all went to get
yogiyogs
Spigen Glas.tR
Anybody knows where to buy Spigen GLAS.tR Curved Screen Protector for Mate 20 pro?
Out of stock in lazada.
JayBeeLwashere
May i know how to enable spotify equaliser in this phone? Cant seems to find in the settings
Sent from HUAWEI LYA-L29 using GAGT
Audiology93
I couldn't find it as well. Its there on my Note 9 and Pixel but strangely not on my Mate 20. I'm currently using the dolby atmos eq
Sent from HUAWEI Mate 20 using GAGT
s-ghost
High Honorary Member
4 hours after using how many % of your battery?
Mine in general is also around 3-4 hours only..
But I suspect that is also because most of my battery life are spent on stand-by. My battery on avg drops 40% a day, and my SOT a day is about 1.5 hours.
For those who have very high SOT, may I know how your day usage is like?
Thanks.
okay so i charge to 100% last night and use it till now, this is what i got:
mainly use to listen music via bluetooth earpiece, browse web and fb for today, that's about it.
NeonX
That's quite good already lol
Sent from Google PIXEL 3 using GAGT
1982-1994
Dual network, AFAIK, M1 drains battery upon the phone is left on standby probably due to the lack of fast dormancy, my guess lah.
Whenever I checked my battery usage, the first one always 'Android system' instead of 'screen'. Then the battery was drained like 1-2% each hour.
That's why i ported to singtel after 10 years.
I'm not sure on circles line but maybe the same too since it is tapping on M1 infrastructure?
Why not using wired earpiece? BT earpiece is not healthy lol.
Your SOT is 303mins and have used 67% battery.
303/67= 4.5mins average drain for every %.
For fb, are you using the standalone app?
What browser are you using?
s-ghost
is it...actually i not very savvy with SOT, like supposed to keep a lookout for what :s13::s13:
why BT not healthy? :s13::s13:
more convenient sometimes
fb using the app, browser is google chrome :o
1982-1994
BT emits slight radiation.
If you don't give a hoot on battery, just ignore what previous post.
s-ghost
icic
I just curious about it, like if my phone is performing normally because I see users here the SOT like very long then mine like quite short :s13::s13:
Abyssal.Xuan
With 12 hrs and 40mins away from the charger hahahaha.
But I do agree, battery seems to drop faster after the update. SOT used to be on the higher 3hrs side, some days even 4hrs.
Though, I did manage to get 1day and 4/5 hrs yesterday but that only got me 7hrs SOT.
1982-1994
The best battery test is to pak graphic intensive games. Is there such games?
jyod24
Anyone had issue this issue where the phone will not be able to detect the Sim card suddenly and a restart is required. My mate 20 pro is frequently dropping connect with the Sim this way. Not sure if it's software or hardware issue.
