Just checking, anyone's having the LG screen on their m20pro but not having the green light issue till date?
I'm on LG Panel since Launch Date in Oct. No issue at all. Btw, LG-01-18-10-51 previously and after update change go 53.
Thank you
No i was civil. He got us either a refund or replacement at JP branch
While there are definitely many cases of green tint, and I do think it's an issue,
I suspect the percentage of those without green tint should still be higher than the percentage with green tint.
Anyway, the 2 M20P phones in my house is showing no signs of green tint after using more than a month. Both are LG screen.
other normal cable also can support super charge ?
There's much cheaper options locally, also beware other countries might have different versions, if they're selling china versions which are cheaper, they dont include google services at all because it's banned there. They also have different reception bands so ur calls might not work as well here.
I bought mine in China, works perfect in Singapore and surprisingly google services is installed and working![]()
Why not get Sony XZ2 Premium which has no notch? Camera performance is on par with the phones you mentioned.
Guys.. where can I get the glue full screen protector for M20 Pro?
Sent from 10char using GAGT
Anyone for feedback on mobile hardware? The SP covers full rightRed White mobile was good. But now the type of SP is different and I read some complaints about it. but the way they apply it is very good.
Maybe Xgear at waterway point? Mobile Hardware I also saw, but no experience
Dont trust the Huawei stores. I applied at 313. At home I realised the SP one side has mucb more space, while the other side is way too close to ny UAG case. The SP pops up. I also saw some glue at the bottom, close to the charging port.
Which is better ah buddy? I got no experience with anyvimobile, casefactorie, moby
Sent from HUAWEI LYA-L29 using GAGT
I went for the cheaper option @25 from vimobile.. glass is not branded using loca glue adhesive (so far decent quality - not a lot smudges), fingerprint sensitivity okay.. casef/moby uses zeelot @49.. maybe those tried can review.Which is better ah buddy? I got no experience with any
For myself I sure buy cheap, for wife buy zeelot lol. Thanks, I'll get it fixed and review hereI went for the cheaper option @25 from vimobile.. glass is not branded using loca glue adhesive (so far decent quality - not a lot smudges), fingerprint sensitivity okay.. casef/moby uses zeelot @49.. maybe those tried can review.
I did mine at GW mobile. Sim Lim Square. Paid 39 during the Black Friday sale.No i was civil. He got us either a refund or replacement at JP branch
Nope .. no use .. and there is no click sound when you put in the Nano SD card into the reader .. also I don't think its the connection from the reader to the computer. It reads when I use the normal Micro SD card ... sigh ...Wow nice i always thought that 845 is better than 980.
oO the sound come out from the usb c port? Not from the row of holes?
True, just charging half an hour might give me more than half a day of power.
im really not a fan of sony's phones.
i just unable to appreciate their design and software.
I dont think there is any need to port Google camera over since mate 20 produce good photos as well.
Porting over does allow you to try out Gcam but the processing is slower than pixel and most of the port over gcam are buggy.
Currently im using redmi note 5, with Gcam ported over, sometimes the HDR processing can take up to 30 secs for 1 photo.
Anyway, does any of you root your phone?
Is there any alternative way to unlock your bootloader?
I find it stupid to pay additional fees to get the code to unlock bootloader.
Anyone here tried to read the Nano SD card using their computer? Please share!
