Huawei Mate 20
1982-1994
Don't anything just bang the table lah, make yourself look like a fool. Also not the CSO fault.
mosprockett
I've found that only Huawei stock launcher is. Most stable...
Other launchers keep getting random crap.like can't connect to camera and other UI quirks..
Posted from PCWX using LYA-L29
1982-1994
I'm using nova launcher, so far so good.
fatesealer
Does anyone have an issue with a burn in screen. My Mate 20 pro has a thick horizontal line across the screen and it's quite obvious when the screen is off. Looks like what seems to be a notification bar marking.
Chuan Chen
You can just go 313 and ask for 1 to 1 exchange. May i know your screen LG or BOE ?
coolhirako
Will they allow me to do so? I mean they can say a lot of things like it's normal etc. Mine is an LG screen.
I just changed mine yesterday. Just said green screen and they record it and dont even bother to check and ask ke come back later for a new set. Just bring your phone there will do , you will given a brand new sealed set
everdomdom
just went to rwm to get their tempered glass. Very satisfied with it, and tried few cases and fit perfectly without glass lifting at the sides. 30 bucks well spend.
tkdboi
need to bring whole box an charger etc?
Sent from HUAWEI LYA-L29 using GAGT
kirium76
Can take Pic to see the coverage?
Sent from Samsung SM-N950F using GAGT
iwillbuy
Anyone using Chrome Remote Desktop app on Mate20 ?
mine is not working, unable to add account
