Aikon
- Oct 20, 2001
Will they allow me to do so? I mean they can say a lot of things like it's normal etc. Mine is an LG screen.
Which batch is it? A. B or C? From the serial you can tell.
If now go buy Mate 20 Pro
Will have issue anot ?
Have they changed the ones with Screen Problem already ?
Can take Pic to see the coverage?
Sent from Samsung SM-N950F using GAGT
How to tell which batch from serial number? Not exactly green line. Just a burn in mark.
Is it normal to see a faint green tint at the sides of the display? Because mine has it and when I look at it from the right side the green tint on the right dissappears but the left green tinted side of my display darkens and vice versa? I'm using Huawei Mate 20 Pro using BOE screen and it has it.
Yes my boe screen has the greenish colour on the round corners too
So is it normal or what? Because mine is the replaced model after the LG incident of green screen.
Bought a electroplated green tpu case from tb. No lifting of rwm glass.![]()
Sent from HUAWEI LYA-L29 using GAGT
Just recontracted and got M20 from M1.
Previous was M10 owner and switched to M20 now.
Any recommendations for the nm card and card reader?
March sure cheaper, but don't get from it show. Most likely retail price with "freebies". Cheaper to just get from Street shop w/o of the freebies. If really wan the freebies, can get from caoousell at a much cheaper price.
Sent from HUAWEI Mate 20 using GAGT
You should continue to use Xiaomi Redmi Note series.
